Author Subject: Valves and lifters
colgti6
I've been told I need new valves and lifters
My question is it worth having the work done or would it be cheaper and easy to put another engine in the 6
Any advise would be helpfull thanks in advance
Adding up the bills for the 6
Posted 20th Nov 2011 at 18:37
thelegendofando
why would you need new valves and lifters?
205 GTi6 - work in progress
Posted 20th Nov 2011 at 18:52
colgti6
Had my head gasket done about a month ago picked the car up and it was really tappy the garage told me it would stop, they said it was the lifters sorting them selves out , so after about 200 miles no change still tappy I took the car bk to the garage they checked the compression and lifters and said they were fine, so I carried on using the car I left work one day and put my foot down to get in front off a truck the car lost loads off power and started making a really bad clanging noise I have spoke to a mate who used to be a peugeot mechanic he said aswell as another mate its the valves and lifters that are at fault
Posted 20th Nov 2011 at 19:25
colgti6
Ow and I've been reassured it isn't the bottom end all the noise is coming from the top off the engine
Posted 20th Nov 2011 at 19:37
I'd imagine the clanging noises are the valves trying to beak free through the pistons.
Posted 20th Nov 2011 at 19:53
colgti6
So its proper fooked then
Posted 20th Nov 2011 at 19:56
Was it a tapper before the garage did the headgasket? If not then the garage bent some valves during the course of the repair and left you with a tapper. Best get on the blower to the garage and politely enquire as to how they wish to resolve the issue...
Posted 20th Nov 2011 at 20:04
Good luck with that sounds like a poor repair to me but I doubt the garage will do anything
Best off getting a different engine
Posted 20th Nov 2011 at 20:17
colgti6
Daveyboy from wot I have said and the noise I have explained wot do u think the problem is I can't put up a sound coz my mate tarret has the car and is proceeding to strip the head down
Posted 20th Nov 2011 at 20:20
Dropped valve I reckon ?
Prob find mashed into the head and piston ?
New engine time if so Angry
Posted 20th Nov 2011 at 20:36
colgti6
It still runs though it's not missing just noisey and no power
Posted 20th Nov 2011 at 20:38
Yeah it will still run as still getting fuel air and a spark just down on compression in that cylinder noise will be broken valve floating around in the head being smashed by the piston into the head
Posted 20th Nov 2011 at 20:48
Should be fairly easy to diagnose Wink
Posted 20th Nov 2011 at 20:54
Yup once the head is off I reckon there will be a mess in one cylinder
Sad
Posted 20th Nov 2011 at 20:59
colgti6
Could it be repairable or is it new engine job
Posted 20th Nov 2011 at 21:23
you'll never know till its all apart.
Posted 20th Nov 2011 at 21:46
If it's dropped a valve the head will be wrecked and the chances are that metal fragments will have found their way into the bearings in the bottom end and caused havoc there too. Get the compression test done, if there is a valve issue compression will be practically zero. If that turns out to be the case, buy a second hand lump. I think Ratboy still has a rebuilt one up for grabs.
Posted 21st Nov 2011 at 13:13
