reason i ask is, i need to strip my pump to make way for a phase sensor setup so i can run cosworth management
its either that or make up a toothed wheel for the inlet pulley.
| Author | Subject: gti vacuum pump |
JWP EFi
will the brake servo still function if i do away with vacuum pump? and take vacuum off inlet with a 1 way valvereason i ask is, i need to strip my pump to make way for a phase sensor setup so i can run cosworth management its either that or make up a toothed wheel for the inlet pulley. |
there's a cam position sensor on there already ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
welshpug! wrote: there's a cam position sensor on there already ![]() i know that its no where near compatible with cossie ecu, iirc gti6 phase sensor has 3 pins, cossie only has 2 Anyway, what about vac pump??! |
JWP EFi
didnt explain very well, basically im planning to put new phase sensor gubbins inside vac pump, not do away with itall together |
