Author Subject: Locking cam timing
docwra
Is there a guide to locking off the cams before removing cambelt? I have my inlet cam advanced and dont want to lose it when putting a new bottom end on Smile
Lots of Nissans, two 306 GTI-6's. They are catching up! Big grin
Posted 17th Nov 2011 at 11:43
Disco_Stu
I used this technical guide in the download section
Link
Peugeot 306 Gti-6 Track car (soon to be supercharged)
Project page
Blog
Posted 17th Nov 2011 at 12:17
Before removing the timing belt pin the cams and crank pulley in their relative positions. Take off the cam covers and mark the cams against a reference point in the head with some paint (you will need to degrease the area you want to mark with a solvent beforehand though)
Posted 17th Nov 2011 at 22:37
Denis
Standard timing marks / pin locations are obviously only for standard cam timing. Unfortunately because of the way the belt tensioning is done on this engine, to get the right tension, you have to loosen the sprockets and the cams have to be locked in standard positions.
So, the procedure is as follows:
- Rotate the engine until the crank pulley and exhaust cam timing marks line up and pins can be inserted
- Measure/mark how much the inlet cam was advanced.
- Rotate the inlet cam to line up with the timing mark
- At this point all timing marks are lined up and the cams can be pinned to remove the cambelt
- Do whatever needs to be done with the engine: take the head off, etc.
- Refit the cambelt and tension it up
- Rotate the inlet cam to the required advance
As for how much to advance the inlet cam, I have not checked it myself, but the figures that I found were: standard inlet lift 0.8mm @ TDC, maximum safe lift ~1.4mm @ TDC.
Cherry Red Rallye Project thread
WhiteBMW M140i
Posted 17th Nov 2011 at 23:14
