Author Subject: Will 195 65 15's fit?
monkeyman
I've been looking round for some winter tyres and seen a lot of 195 65 15's on ebay, but will these fit on a 306? Rear is standard height, front is slightly lowered.
Forum Search Clicky
Posted 16th Nov 2011 at 14:12
simonjames
doubt it even if it was raised
MY EBAY ITEMS
07943066306
Posted 16th Nov 2011 at 14:20
might get away with 185 60, maybe 65, doubt 195 will at all
Posted 16th Nov 2011 at 20:37
rallyeash
as a rough guide 195 55 R15 will have a sidewall height of 107mm (depending on tyre pattern etc)
195 65 R15 will have a sidewall height of 126mm
difference being 19mm, so half that will give you a 9.5mm car raise and an extra 9.5mm up in the arches.
so on thats theory should fit, as the sidewall number is a percentage of the width ie 65% of 195
309 3dr K20 Type R
Posted 16th Nov 2011 at 20:56
eddiebeano
65 profiles look absolutely huge up against 55s. I recently had a set of c5 steelies with 65 profiles and there was no way there were going to fit!
team: Stealth Ninja
Posted 16th Nov 2011 at 20:59
your main issue will be rear bumper and front spring pan clearance.
plenty of 50 and 55 profile winter tyres out there
Posted 16th Nov 2011 at 22:46
darzmat
i got a set of second hand cyclones that came off of an HDI and they were 195/65/15's
so i would assume they would fit. if its only 9.5mm its going to add on, judging by my arches they would definately fit
Posted 17th Nov 2011 at 00:33
eddiebeano
team: Stealth Ninja
Posted 17th Nov 2011 at 00:55
monkeyman
I think Sidewall will need to be x 2, they do look about 20mm wider each side. I did a quick space check with my 20mm kneeling pad and they would fit in, I'd just have to not drive over any bumps LOL
thanks eddiebeano, I used a different tyre calculator but it didn't make the new tyres look as big as those
Forum Search Clicky
Posted 17th Nov 2011 at 08:57
