Author Subject: SC Query
Does a low boost SC setup still use a MAP sensor?
Posted 15th Nov 2011 at 10:16
yup, they all do.
edit, why the hell are you asking this, you have a supercharged 6 Laugh my ass off
Posted 15th Nov 2011 at 10:18
yup, they all do.
Laugh
As my supercharged 6 is broken and suspect its the map sensor. Car is not with me so can't check, and want to try and get one purchased today.
Thanks mate Big grin
Posted 15th Nov 2011 at 10:21
symptoms = ???
wait. you posted in general
SIGN UP U TIGHT FISTED BUGGER AND STOP ASKING QUESTONS IN GENRAL SECTON
thought i'd get that one in
Posted 15th Nov 2011 at 10:30
rikky wrote:
symptoms = ???
The car was fine all over the weekend when I was using it and as on monday morning it wont idle at all. If I start the car and hold the throttle, its fine. If I let go, it dies straight away.
I am a paid up member, but I wanted a quick answer and some members may of known the answer, but not able to tell me if they were not paid up members Roll eyes
Posted 15th Nov 2011 at 10:34
Laugh my ass off chill i'm messing with you, i saw your membership thing LOL
Posted 15th Nov 2011 at 10:54
Yeah I know, just making a point as I knew someone would mention it Laugh my ass off
Posted 15th Nov 2011 at 11:01
check which one you have, there's two different plugs.
Posted 15th Nov 2011 at 12:49
ryangti6
Have you tried unplugging it to so if it will idle then? They will usually tick over just not very good with it unplugged and seem a bit lazy to rev.
I'm thinking if it still wont tick over then it's probably not the map, I assume you've checked Icv? Also IIRC you need to extend some of the sensor wires for the Sc conversion, have you checked all this is okay and something hasnt pulled out etc?
Ryan
Posted 15th Nov 2011 at 13:07
I had a quick check in the dark the other night and couldnt see any breaks etc. I didnt try unplugging the MAP, will give it a try when I get home.
Posted 15th Nov 2011 at 13:10
gtisid
is it the icv popped out the throttle body...clips break on the buggers
mmmm actually it maybe the air sensor cant remember what it is on the underside of the throttle body. remember it happeneing on stans and someone elses
pugless
Phase 1 GTI 6 1996-1997
Subaru Impreza GB270 2007-2008
rare spiderman comics
same day international courier
Posted 15th Nov 2011 at 16:02
chrisd306
Mine done same I replaced stepper motor and was fine after that, but I'd check the extended wiring first tho.
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 15th Nov 2011 at 16:19
greenbelt
+1 for the stepper motor. Do you know how to check if it's working properly?
Standard Black 6
Black HBSC6 Smoke
Posted 15th Nov 2011 at 17:00
No idea Laugh
Thanks for the suggestions guys, going to get it all checked out tomorrow afternoon when I have time and light Smile
Posted 15th Nov 2011 at 17:34
antcla.85
Try here
Tested mine at weekend, only read 48 ohmes on each so prob needs replacing.
Life is short, make it interesting
Buy a Peugeot!
Posted 15th Nov 2011 at 17:43
smegal
Mine kept firing the end off the stepper motor I bought a pattern one and it did the same. Bought another genuine one and all was fine.
Ex SC-6
Now in a Megane R26
Posted 15th Nov 2011 at 18:05
davewagon
Mine did this when I took it out to clean it. Ping'd off and made a bid for freedom down my street.
I just WD40'd it and refitted it to the end, should I have replaced it after it had flew off?
Dave
Edit: Chris, give me a text or message if you eliminate the MAP or still want a hand tomorrow!
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 15th Nov 2011 at 18:14
I will let you know, thanks Dave Thumbs up
Posted 15th Nov 2011 at 18:43
Issues caused by faulty ICV.
Thanks guys Big grin Cheers
Posted 17th Nov 2011 at 08:38
