Author Subject: New noise
aaron6
Hi all, my car has started making a tapping noise from yhe left side of the head. It runs fine and has not had a belt change so im confident its not a valve. Any other ideas I can look at? Smile
Posted 15th Nov 2011 at 06:59
Spark plug loose.
f*ck me how many times have I typed that in the last 6 years Laugh my ass off
Posted 15th Nov 2011 at 09:15
aaron6
Im ckecking those at lunch, done 1 on 1st break and was ok though. other than that, what else can cause this? It kind of sounds like a commpressor.
Posted 15th Nov 2011 at 10:53
Which one? Try to undo them by hand (without ratchet) as that'll give you an idea if they are loose. Harder to tell with a ratchet.
Could also be exhaust manifold gasket or a dodgy but unlikely tappet.
Posted 15th Nov 2011 at 11:16
aaron6
Okay cool, il try on the next 3 at lunch time. Could be exhaust gasket I guess. Il try the plugs and go from there. Smile oh yeah, the one I did so far was the left one as you look at the engine. I must also, the fit of the coil pack to plug felt loose, almost as though it was just sitting on the plug. Is this normal? Or do the clip on?
Posted 15th Nov 2011 at 12:26
they should bolt down.
Posted 15th Nov 2011 at 12:51
aaron6
Nah, I meant the fitment to the top of the plug inside the coilpack. Done it lunch, plug no.2 was a bit loose. All sorted now though. Cheers boys. Smile
Posted 15th Nov 2011 at 15:21
