Author Subject: rgy & rgx con rods
JWP EFi
Turbo Legend!
i know this is not a gti6 specific subject but here goes
Are there any differences between the RGY and RGX (8v turbo) conrods?
I have a mint 8v turbo bottom end but it has the dished pistons which i believe are not suitable with a 16v head,
my plan is to source a set of C20LET pistons and use them with my 8v rods, i just need to know if the rods are
as strong as the earlier RGY ones???
I had a passenger seat run in a 205 16v turbo running a citroen xm bottom end, 320 bhp with t34 and cossie management
guy said its been in there for nearly 4 years and not had any issues with it throwing rods etc
Guy goes by the nickname duffie if any of you know him, great guy btw
sorry, going of topic slightly lol
Posted 7th Nov 2011 at 21:24
JWP EFi
Turbo Legend!
Anyone...
Posted 7th Nov 2011 at 21:44
all 8v rods are the same, even the non turbo engine, which also used the same head and crank.
you could just get an S16 and skim the pistons, no need to faff sourcing bits, they're all there ready.
could just run boost through the standard compression, mapped properly of course.
Posted 7th Nov 2011 at 22:37
JWP EFi
Turbo Legend!
planning to use cossie L8 management, don't feel confident with 10.8:1 compression and boost,
i totally understand what your saying, but having witnessed a 300 odd brake 205 i just feel the need to follow whats been
tried and tested
BTW, what about machining my dished pistons???
any info, good or bad would be very helpful
cheers
Posted 7th Nov 2011 at 22:52
JWP EFi
Turbo Legend!
meant to say L8 management with 'live mapped' chip!!!!
Posted 7th Nov 2011 at 22:53
S16 is only 10.4, you could get the dished pistons machined, but rather more complex than just lopping a straight mm or so off the flat topped S16 pistons.
how much does cossie management cost?
Posted 7th Nov 2011 at 23:16
JWP EFi
Turbo Legend!
already have ecu, loom, sensors. Now looking for complete cossie distributor so i can fit phase sensor setup to the
vacuum pump
probably around the 500 mark, ish. did consider megasquirt
yes its alot of work, but ive already stock piled bits n pieces so going to persevere (or try to!)
i believe ecosse approached their 'T16' sedan in a similar manner, trial and error i guess, what its all about
What confuses me is how can you get away with using factory parts, when peeps like Binka had an engine with all
the forged goodies and still threw a rod in the early stages...
Posted 7th Nov 2011 at 23:35
distributor Shock Meh
Posted 8th Nov 2011 at 10:54
JWP EFi
Turbo Legend!
L8 ecu, you can buy a DIS conversion (140 quid) so that you can run twin ignition amplifiers and a normal twin coil pack. this is now a
popular upgrade for the cossie guys who want to ditch the unreliable cap and rotor arm
as i said, its alot of work to do it but it 100% works none the less
Posted 8th Nov 2011 at 14:39
