Author Subject: dodgey clocks dancing
richy5118
hi i have a gti6 on a p reg i have awful dancing clocks when i change gear on the car also the abs light comes and brake tend to be little effort. and it knocks the stereo off and also on the odd occasion it cuts the car out , i had a new cat fitted this week but it was doing this before the cat was repalced. can some please advise me the problem is annouying greatley. any info would be appriciated thanks rich 07909093755
possible the tidyest 306 gti6 for its year
Posted 30th Oct 2011 at 17:44
greenbelt
Sounds like a loose earth connection.
Check the main ones coming from the battery negative terminal that go to the chassis rail just in front of the battery box and the one on top of the gearbox Wink
Standard Black 6
Black HBSC6 Smoke
Posted 30th Oct 2011 at 18:22
richy5118
green belt will do mate thanks mate appriciated
Posted 30th Oct 2011 at 18:24
greenbelt
No problemo Smile
Standard Black 6
Black HBSC6 Smoke
Posted 30th Oct 2011 at 18:25
richy5118
absolute night mate pin pointing it could it be loose, just thort on head lights flicker too im sure its got to be a bad connection somewhere
Posted 30th Oct 2011 at 18:27
greenbelt
Start with the main terminal on the battery and work around to the other earth points.
Standard Black 6
Black HBSC6 Smoke
Posted 30th Oct 2011 at 19:35
pugjim
By the sounds of your problem im guessing your car is blaze yellow and number plate ending in UAC?
Posted 31st Oct 2011 at 18:17
there's lots of those about PugJim LOL:
Posted 31st Oct 2011 at 18:26
richy5118
pug jim how do u know that??????????????????????????????????????
Posted 1st Nov 2011 at 16:30
richy5118
only trips clocks and stereo when u move the gear stick?????????????????????????????????????????????
Posted 1st Nov 2011 at 16:35
pugjim
The blaze yellow UAC dancing clocks syndrome strikes again.
Posted 1st Nov 2011 at 18:58
richy5118
cars now sorted it was an earth cable that was snapped next to battery try happy times
Posted 2nd Nov 2011 at 18:48
pugjim
thats the one i told you to check in the pm, good to hear you got it sorted. Nice to see a new member using the forum correctly and paying to gain access to the technical section when they have a problem.
Posted 2nd Nov 2011 at 21:39
richy5118
new to it mate im trying lol
Posted 11th Nov 2011 at 22:19
Bad earth on the battery or the chassis from the battery
Posted 11th Nov 2011 at 22:30
