Author Subject: adjustable rear axle camber and caster
j collen 306
Looking for a rear axle for my race car must be adjustable camber and caster
Posted 30th Oct 2011 at 08:14
http://www.hh-ms.com/HHMS_rear_independent_sus.htm
that's the only one I know of, you can get stub axle kits and modified trailing arms to get different settings but they will not be "adjustable"
no need for it to be adjusted if you choose the right initial settings though.
caster can't be adjusted on trailing arm btw...
Posted 30th Oct 2011 at 08:29
midlife
Think you need to have a look at how your rear beam actually works.
Castor is only found on 306 front suspension ie the angle of the front strut from vertical. Upto a point the further the top of the strut is behind the bottom of the strut the better.
Nothing is adjustable on 306 rear beams, but you can get the trailing arms machined to achieve the desired amount of negative camber & toe in you're after.
If you pm crf450 on here he can do this work for you. If you have no joy contacting him on this forum google bridgecraft engineering & email Martin direct.
Have a look in the projects section for midlife's Rallye for more info. And have a look on YouTube for 306 ringtaxi crash to see what these suspension mods can achieve.
Don't forget uprated torsion bars & anti roll bar..
Cool
Team 330™Cool
Team "no front end or engine"
Posted 30th Oct 2011 at 08:35
midlife
Doh too slow Laugh my ass off
Cool
Team 330™Cool
Posted 30th Oct 2011 at 08:36
