How much will a 0.5mm block decking ,and a 0.2mm head shim retard the cams on a mi16 engine?Can this be corrected with the tensioners?
displaying posts 1 to 2 of 2
| Author | Subject: Block decking |
peugeot96
Regular Location: verdal Registered: 14 Sep 2011 Posts: 218 Status: Offline |
How much will a 0.5mm block decking ,and a 0.2mm head shim retard the cams on a mi16 engine?Can this be corrected with the tensioners? |
as they have two tensioners and the cams are pinned it wont affect the timing, similarly, as the XU10J4RS cam pulleys are adjustable to a point, they will take up any variances.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
