hi all. ive got a few issues which i hope an expert can clear up. ive read the FAQ about the cambelt change (great post) i got the car as a non runner so i have no way of knowing what the timing was before as the belt snappedso i timed up the car, runs ok but very flat and struggles to tick over. compression is very good running at 215 215 210 215. its fitted with uprated cams. which i dont have a name for. if i put the 8mm pin in the front of the engine through the crank pully it runs as above, if i follow the post and remove the starter and put a pin in the hole at the back its almost 2 teeth out in comparison to the front pulley marks. and if i time it up on the rear mark with a drill through into the flywheel it bearly runs at all.
i knew the car well as it was a friend of mine and i knew it ticked over fine and pulled well. want to eliminate the timing problem so is there anyway else of doing it with a dti guage or smething?
thanks
john
joh_rdy
