Author Subject: Fault Code P0177
darkgti6
I found this code in my ECU earlier (much thanks to Hovis mate Paul)
From searching online the fault code means 'fuel composition sensor' fault and/or issue.
Does anyone know where this sensor is? My problem is manifesting itself as a starting issue. Sometimes it will start first time sometimes it takes a few goes but otherwise she runs fine. Would this sensor be in fuel gauge sender unit?
Is this it? What the hell is this thing anyway still dont know what it does?
Team Peugeot Sport 308 Gti�
Posted 23rd Oct 2011 at 18:34
goes to the fuel vapour canister on the inside of the drivers wing, presumably a valve. mine also doesn't work, mainly because it is decomposing on a tip somewhere because i got shut of it
Posted 23rd Oct 2011 at 18:45
darkgti6
is this the fuel composition sensor though? Ive seen the cannister, in haynes it says its something to do with environment control whatever that meansCrazy
Posted 23rd Oct 2011 at 18:50
darkgti6
Also as soon as the ecu was cleared and the engine started up the fault code returned straight away.
Posted 23rd Oct 2011 at 18:51
Rich E Forum Admin
There isn't a fuel composition sensor on these cars.
What was the code read with?
Posted 23rd Oct 2011 at 19:31
darkgti6
Not sure but i will find out. It was a red hand held unit with lcd display. I didnt use the thing but you had to input a the vehicle type into it and i dont think the gti6 was specifically listed.
Im begininng to wonder if its the lambda causing problems Hmm
Posted 23rd Oct 2011 at 21:28
mabgti
NV motors
very much doubt thats correct..
you need to scan it on a peugeot planet diag
even the launch kit we use doesnt pick up a few sensors on the 6.. but the planet system is awesome!
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 24th Oct 2011 at 01:34
darkgti6
Cheers mab, yeah seems wrong to me. I've been hunting this starting issue for some time now. Seems a proper diagnostic is the only thing left to do now. I'm running out of ideas.
Posted 24th Oct 2011 at 08:24
darkgti6
Actually there's one last thing to try. From the symptoms it could possibly be a fuel pressure issue. Ages ago I pointlessly swapped my oe fuel pump and sender unit for a mickey mouse quentin hazel unit thinking the original sounded rough. This was back when I was living with the rents and put it in the garage loft but the old man lobbed it out I think.
So the plan is to hit the scrap yards to try and find an original to use to see if that cures it - then try a diagnostic. It's annoying because otherwise she runs fine but you look like a right tit sometimes when it takes 3 or 4 cranks over to get the.thing started.
Posted 24th Oct 2011 at 08:35
mattgti6phase2
Can the pressure be altered on the OE item?
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 24th Oct 2011 at 10:16
nope, its 3 bar max affected by vacuum in the inlet.
try turning the ignition on+off a few times to prime the system, could be the one way valve in the Fuel pump has failed.
Posted 24th Oct 2011 at 10:19
mattgti6phase2
So the above problem could also be an air leak on the mani.
5 x a 306 owner!
Posted 24th Oct 2011 at 10:58
darkgti6
Yeah Paul said about this yesterday, it would explain why it takes a few goes to get it going. Gonna head down to the scrappy in a bit and see if there's any gtis down there. Got a half day today.
In the mean time I will give that a go and see if it does the trick.
darkgti6
Been down this route, all air leaks on the standard air intake have been fixed. Phillipm manifold gasket and injector seals have been renewed. Def no air leaks.
Posted 24th Oct 2011 at 11:19
doesnt need to be a gti.
Posted 24th Oct 2011 at 11:44
darkgti6
sweet, theres an xsi hatch and 306 estate down there any of those do?
Posted 24th Oct 2011 at 13:02
yup, as long as the estate isn't diesel or a late TU, or a phase1.
Posted 24th Oct 2011 at 14:20
