Author Subject: top engine mount rubbers?
jimmyhackers
just a quick question here which i think i know the answer to but i want reassurance.
the two pyramids shaped rubber engine mount on the top. should they be able to rock back an forth due to space. or shoul both rubbers peaks be touching the metal enclosing?
i figure mine are 16 years old and knackered and need to be replaced?
thanks for any info
Posted 22nd Oct 2011 at 11:02
mik
They are not a key structural part of the mount, more like bump stops. They don't really do much in terms of stopping the engine moving, all they seem to do is stop the paint from getting damaged. Better to look at the mount itself - is there excessive engine movement? If so it might be fractured and need replacement. It can look OK but is fractured and only the weight of the engine is holding it together. Or the cradle might be cracked (not uncommon but relatively easy fix done by daveyboy on here). If the mount itself is actually still OK you can get it chocked which reduces engine movement. A properly supported engine helps get power down, improves gearchange quality etc. If the mount is original chances are it's fubared anyway by now.
I'm doing mine soon - after I've sorted the rear axle bushes.
Cherry Rallye SOLD
Posted 22nd Oct 2011 at 12:10
monkeyman
A while ago someone on here was selling top mount chocks, there were basically a right angle of 2-3mm aluminium that reduced the movement within the mount. Im sure you could make your own.
Forum Search Clicky
Posted 22nd Oct 2011 at 21:03
or just buy a new buffer.
Posted 22nd Oct 2011 at 21:09
jimmyhackers
yeah tbh my old 1.4 had the same problem and i solved it with a wooden chock
ive literally just done the same on my gti and FOOKIN ELL
car is super sexy smooth to drive now Smile
the judder man has been banished : D
Posted 12th Nov 2011 at 12:00
I'm going to make up chocks soon, just need to copy the one I made for myself
Posted 12th Nov 2011 at 14:42
jimmyhackers
i just got a pit of 6 mill ply, 1 inch by about 6 used a bench grinder to make one edge pointed and then cut a groove in the centre. i greased the groove and aroldydeted the other side then just hammered it into place. using the esiting hole i put a little screw through just for peice of mind
Posted 12th Nov 2011 at 22:00
