Author Subject: Fuel Pressure Regulator with Throttle bodies
I'm in the process of knocking up some R1 5PW throttle bodies for my track car, i just wondered if i would be as well buying an adjustable fuel pressure regulator or whether the fueling is easily sorted out whilst being mapped?
I think i'll be using the standard ecu for the remap, most likely taking it to chipwizards for it to be done.
I have tried searching for answers on this but nothing really came up, im loosely following what yanni did and noticed he needed a slightly higher fuel pressure.
Cheers. Smile
Posted 17th Oct 2011 at 19:35
no need if the injectors are sized correctly.
Posted 17th Oct 2011 at 21:12
I'm aiming to use the standard injectors.
The standard cams will also be used too so i'm not expecting too much of a power increase.
Posted 17th Oct 2011 at 21:14
