can anyone help??
cheers
| Author | Subject: rgy flat tops |
JWP EFi
Evening chaps, i'm looking for a set of flat top pistons for the xu10j2te engine, i have the dished type and are of no use to mecan anyone help?? cheers |
you know the dished type are slightly higher compression right?coud always get them machined a little. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
yes i know that but i need the flat tops for the valves to clear. Btw i'm putting a gti6 head onto the 8v turbo bottom end and correct me if i'm wrong but my dished pistons are not suitableBefore anyone shouts out 'forged' this that and the next, its a budget project so i can play about with megasquirt and my cossie T3. Not too fussed if it all goes bang, but would feel better with the flat tops unless anyone can advise me otherwise Cheers again guys |
if youre on a budget I'd just leave the gti6 pistons in there.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
JWP EFi
welshpug! wrote: if youre on a budget I'd just leave the gti6 pistons in there. ok, assuming i did this in conjunction with say a decomp plate from the likes of dp engineering, would i be able to run say ~ 10 psi with my T3 turbo?? Looking for around 220 bhp, iv'e done the 8v turbo thing, i want a better spread of power across more of the rev range. i have a vgc complete 6 engine with perfect bores that came from a 2002 xsara vts also have a good condition TCT engine with factory uprated pistons and rods but dished pistons that sit higher up the bore ...what do i do, 6 engine with decomp plate, machine my TCT dished pistons or look out for a set of RGY flat tops??? cheers PS i know this is in the wrong section! |
