Author Subject: Adjusting Pedals
xaero1
Hi chaps,
The only thing I don't like about my Rallye is the fact that the accelerator pedal rests at the same height as the brake pedal. (This is unlike 90% of other cars I've seen where the pedal rests lower down).
Now I know exactly why it was designed this way - it makes it easier to heel/toe etc - however for me I find it really uncomfortable. I'm 6'4" with long legs so leg room is essential for me. With the accelerator pedal resting so high I'm constantly having to "pull" my foot back and it causes pain down my shin on long journeys.
Anyway, enough of the sob story as I've had the car 2 years now and have been too stubborn to do anything about it!
I'm asking, is there any easy way to adjust the accelerator pedal?
Would it be a case of fitting a slightly shorter accelerator cable and taking a pedal from another Pug, for example? Has anyone done it or tried it?
Light travels faster than sound. That's why some people appear bright until you hear them speak.
Posted 26th Sep 2011 at 11:31
Move the seat back a bit?
Posted 27th Sep 2011 at 08:03
xaero1
One step ahead of you there chief. But I still need to adjust the pedals Thumbs up
Posted 27th Sep 2011 at 08:30
The throttle pedal's a pretty simple arrangement if you look under there, but it does actually move the cable from its fully up position until you hit the floor, so I don't really see what you could do easily.
Perhaps re-weld the pivot part at a different point on the pedal assembly?
Posted 27th Sep 2011 at 08:36
xaero1
Hmm, I think getting a cable that's 1-2 inches shorter might be the only option Sad
Posted 27th Sep 2011 at 08:38
The cables have one bare end, so you could simply cut it down, however that would result in the pedal being higher, not lower.
Posted 27th Sep 2011 at 09:03
monkeyman
There is an adjuster at the throttle end to give you some slack. You could possibly weld a bit of metal to the pedal arm to stop it returning fully, but then you may not get full travel/full throttle opening.
Forum Search Clicky
Posted 27th Sep 2011 at 11:50
Or adjust it the other ("man"Wink way, and tighten it up so you get full throttle but can't go below 4k revs Yes
Posted 27th Sep 2011 at 11:52
Glue a thicker pedal rubber on the brake pedal?
Posted 27th Sep 2011 at 13:53
xaero1
Nope, I definitely need the accelerator pedal resting further down as it kills my leg having to keep my foot pulled "up" all the time.
Posted 27th Sep 2011 at 15:44
I reckon only way is to change where it hinges. Take a look under there as it's hard to picture, but it might be possible to do something.
Posted 27th Sep 2011 at 15:46
Take the accelerator pedal off, straighten out the bend and put a new shorter throttle stop on the floor so you can get full throttle before it hits the stop. Don't let the cable go tight at WOT or you will snap the cable.
Posted 27th Sep 2011 at 16:08
xaero1
Cheers fellas. I'll probably end up taking this to someone who knows what the f**k they're doing (unlike me!) and get a quote. I just wanted to see if anybody here had done this first and if it was an easy fix.
Posted 27th Sep 2011 at 17:03
dragoon
I've got the same problem, and really can't find an easy solution and I lack the ability to mod the pedals too.
If you find any easy solution, be sure to post it!
Team Wheelwhore
Team Limited Edition
Astor 306 Francorchamps RIP
Virtual Blue 208 GTi
quote:
I Love this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh Cool
Posted 27th Sep 2011 at 21:43
The actual pedal's an extremely simple thing, just a bit of bent metal with a bit of tube welded to it.
I'm sure you can sort something on the cheap, it's just a case of making sure you can go from full shut to full open without risk of snapping the cable Yes
Posted 27th Sep 2011 at 21:49
darzmat
im gonna have a look into this tomorrow as i could do with doing the same
Posted 27th Sep 2011 at 21:52
PEDAL FRIENDS!
Posted 27th Sep 2011 at 21:53
xaero1
Team Pedal are GO!!!
Posted 28th Sep 2011 at 09:16
PhillipM might be worth asking, he's good with this kind of stuff.
Posted 28th Sep 2011 at 09:22
mark.evs
I came across the same problem on my uncles clio, it was at such an odd angle it was hurting his back too. I took it off and bent it in a vice to a different angle. worked a treat.
My GTi6 track project
White Rallye project
Posted 28th Sep 2011 at 09:23
cwspellowe
You'd need to move the pedal pivot point further down the pedal and adjust the stopper and return spring. Would give you less pedal travel at the foot end relative to travel at the top. Trouble with that is the possibility of stretching the cable before you reach the bumpstop at WOT and the cable could snap.
Had to look into this when playing with the R1 throttle bodies as the bit of the bodies the cable attached to was a smaller diameter that the OE throttle body mechanism meaning there was less pedal travel. Gave up in the end as it was too much faff.
Bye bye Sundance Kid Sad
Posted 28th Sep 2011 at 12:37
