Author Subject: Funky Speedo / Dash Behaviour!
honestly3k
Hey peeps,
So travelling along at 70mph on the M25 today and i glanced down at the speedo which quite oddly dropped from the 70mph position to 0mph then flew back up again in a quick bouncing motion.....bit odd?
Is it a sign my engine is due to blow up soon?! Unsure
Also when dipping the clutch the other day going around a roundabout the engine management light came on then went straight off again, coincided with a drop in revs and the speedo.....also a bit odd
I know this b*tch is brewing up something for me....i just dont know what. Thumbs down
Any ideas?
Posted 21st Sep 2011 at 17:24
walker_texasranger
that's the milkfloat radar isn't it Unsure probably a near miss Thumbs up
Hilux InvincibleX daily
306 No.13 Doh
Posted 21st Sep 2011 at 17:54
monkeyman
Try removing the shunt fuse, the big solid one in the middle of the fuse box, for 10 mins. You'll have to set up your radio again, but this fixed some odd behavior in mine. After that check the earths and leads going into the back of the instrument panel.
Forum Search Clicky
Posted 21st Sep 2011 at 18:40
honestly3k
Hmmm, is it relay shaped this shunt fuse? Or is it in the midst of all the smaller fuses under the steering wheel?
Not sure how i can check the earths/leads either, never removed the instrument panel either...will have a look in the FAQ section for a how to, cheers Smile
Posted 21st Sep 2011 at 19:38
Speedo dropping out will be the sender on its way prob got cooked as it has a heat shield which some times move or just fall apart ? Just had the same thing happen on the mrs 6 Thumbs up
Posted 21st Sep 2011 at 19:43
honestly3k
Ah will look into that.....where abouts is the sender located do you know?
Is it easy enough to inspect? I will have to try and find it!
Thanks
Posted 21st Sep 2011 at 19:49
Are revs and speed all dropping off at once? Mine was a loose earth cable behind the throttle pedal when that happened, caused some awfully odd behaviour.
Posted 21st Sep 2011 at 21:29
honestly3k
It was just the speedo today that did that funny movement, the engine light i have a feeling my ICV needs yet another clean and wen i dipped the clutch on the roundabout thats why that came up
Posted 21st Sep 2011 at 22:05
mabgti
NV motors
you need a new VSS, they are cheap and easy to replace
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 22nd Sep 2011 at 01:40
honestly3k
What is a VSS, where can i find it, how do i replace it and is it a peugeot only part? Cost?
Sorry but the search button is hiding at the moment! Cheers
Posted 22nd Sep 2011 at 07:38
vss = vehicle speed sensor
need to do mine aswell, same symptoms!
Posted 22nd Sep 2011 at 09:09
