Author Subject: Name that plug?
adiesouthwell
Does anyone know what this plug is from on my 306 GTi 6?
Not had the car long and its been spluttery since i got it and i just noticed this is not connected to anything..
www.theredspottyelephant.co.uk/plug.jpg
www.theredspottyelephant.co.uk/aaaa.jpg
Thanks Smile
OMP Strut Brace
3" Stainless scorpian
Remap
Superchipped
R.A.M Air Kit
Running 170Bhp @ 6500rpm with cert Smile
www.gti6forum.co.uk
Posted 17th Sep 2011 at 20:51
steve954
where is the oil unit? i can't believe it's not there!!!! how is it running? is it tapping at all?
stevie
09 308 gt140 cc
03 octavia vrs
IF IT AIN'T BROKE, IT AIN'T A GTI6
Posted 17th Sep 2011 at 20:55
adiesouthwell
Its tapping like crazy! Oh god tell me you can tell me how to stop the tapping!!???
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 17th Sep 2011 at 20:57
cooper666
spare iirc not used on uk models.
clio r27
ps3 id:cooperkloe
adiesouthwell
ok whats an iirc and whats this about an oil unit?
Thanks.
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 17th Sep 2011 at 20:59
stu
If I Remember Correctly. Thumbs up
Posted 17th Sep 2011 at 21:00
Cooper is right, doesnt connect to anything.
Posted 17th Sep 2011 at 21:10
adiesouthwell
Okk thats good. So whats the oil unit that steve954 means?
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 17th Sep 2011 at 21:18
I think he's having you on mate. Wink
Posted 17th Sep 2011 at 21:19
adiesouthwell
Okayy lol, so any clues on the tapping? Its more of a ticking to be honest, its had a recent head rebuild if that helps?
Thanks Smile
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 17th Sep 2011 at 21:23
Ticking could be injectors or possibly a loose spark plug. Tapping is generally one or more bent valves.
adiesouthwell
Ah right, job for monday then, all the injectors out lol! Thanks Smile
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 17th Sep 2011 at 21:50
adiesouthwell
Is there a lambda sensor on the cat on these cars? because this one has a de-cat pipe and i have a feeling there wont be a lambda fitted lol
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 17th Sep 2011 at 22:18
paul_13
If its had a head rebuild recently, what bottom pulley did the person use to time it back up?
I hope the OE hasnt slipped as it'll be another head rebuild time Sad
Bent valves
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 17th Sep 2011 at 22:21
Yes these cars have Lambda's in the Cat, my decat has a lambda in it too, it will probably revert to overfuelling if theres no lambda plugged in to stay on the safe side.
Posted 17th Sep 2011 at 22:23
woody.
I have the exact same thing and was pretty worried as well, but as stated its a spare.
Posted 18th Sep 2011 at 15:34
adiesouthwell
well its definately overfuelling because it gets very hot. The timing has been checked and its set right, same mechanic says there are no bent valves but he thinks its been run very low on oil at some stage in its life, forgot to ask him about the lambda on the de-cat, reason i think its not got one is that i got the cat in the boot of the car when i got the car and the lambda is still on it!
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 18th Sep 2011 at 16:14
paul_13
If he's checked it using a standard pulley thats slipped, it will appear fine but valve/piston contact will of occured. It will all line up using the timing holes but the crank pulley may of slipped and when it's timed back up it will be in the wrong position.
You can only be sure if you use a 205 8v pulley or a lightened pulley from Rich W.
Only the smallest amount slipped will result in bent valves.
Posted 18th Sep 2011 at 23:25
adiesouthwell
Would it even run if it was out? or bent valves?
Its ticking and there is a bit of delay sometimes when i boot it Smile
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 18th Sep 2011 at 23:29
paul_13
Is it more of a ticking or a pronounce tapping?
Injectors are loud but not too loud.
Do the mechanic mark the belt or use the cam pulleys and bottom pulley to time it?
Whats the mileage on the engine/car?
Posted 18th Sep 2011 at 23:46
walker_texasranger
Is this the Blaze one that was up at £500?
Hilux InvincibleX daily
306 No.13 Doh
Posted 19th Sep 2011 at 15:28
adiesouthwell
Whats a blaze one? I havn't tried selling it recently.
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 20th Sep 2011 at 17:18
paul_13
Blaze yellow aka gold Wink
Posted 20th Sep 2011 at 17:39
adiesouthwell
Ah right, well no i haven't had it up for sale recently so probbbb not lol Smile
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 20th Sep 2011 at 20:39
walker_texasranger
Ah ok, Just there was a blaze one for sale in Halifax very recently for cheap money that was a tapper by the vendors admission, thought you might have bought it that's all Smile
Good luck sorting the noise, go with the cheap suggestions first and progress from there...... Any pics of your sewing machine LOL we like pics Thumbs up
306 No.13 Doh
Posted 21st Sep 2011 at 16:11
