Author Subject: Camber
speedo306
How do you set back the camber on the rear suspension? My near side wheel is touching on the inner body. I refurbished the rear suspension with all new parts. Cheers
RJ
Posted 16th Sep 2011 at 12:38
cwspellowe
It's preset with the way the railing arms are machined, as far as i'm aware you can't just adjust it.
Could it be a bent stub axle?
Bye bye Sundance Kid Sad
Posted 16th Sep 2011 at 13:00
yup, bent stub or arm.
Posted 16th Sep 2011 at 13:13
cornish_pug
Will heating it up with an oxy torch & easing it back to shape be any good?
Team Diesel
Posted 4th Oct 2011 at 22:01
no
Posted 4th Oct 2011 at 22:17
cornish_pug
Thinking about it once it's bent it's knackered. I've got to do mine at some point. Luckily I can press them out at work on a nice big fly press.
Team Diesel
Posted 5th Oct 2011 at 06:35
Pressing out the spindle won't do you any good if it's the arm thats bent Wink
Posted 5th Oct 2011 at 14:34
cornish_pug
How can you tell which one is the culprit?
Team Diesel
Posted 5th Oct 2011 at 18:11
I suppose you could get the car on level ground then use an inclinometer on the rear brake flange, I think the standard rear beam has one degree of negative camber. If thats right then the only thing that can be bent is the spindle.
Posted 6th Oct 2011 at 11:08
