Author Subject: "Cracking" start to a new build
pete_rallye
Started stripping an engine today to rebuild... spot whats wrong-
Did you see it?!
Close ups-
Obviously its scrap now, but has anyone ever seen this before? Any ideas what could cause it? Head looks ok, although its had a massive amount skimmed from it. Bought as head gasket failure engine, had a non standard fibre type gasket fitted...
Lap of the 'ring
Posted 15th Sep 2011 at 22:43
cwspellowe
Black hammerite'll sort that. Worked wonders all over my motor Laugh
Did you buy the block or was it one spare? Any cracks between oil/water channels or just the water jackets?
Bye bye Sundance Kid Sad
Posted 15th Sep 2011 at 22:45
pete_rallye
Just those cracks as far as I can see, only checked it visually though.
Lap of the 'ring
Posted 15th Sep 2011 at 22:47
Overheating will be the cause Pete, loss of coolant due to a failed rad or incorrect bleeding after a coolant change is the most likely reason.
Posted 16th Sep 2011 at 16:57
seen it a few times but not in person, have those pistons been touching the head? weird clean spots on them..
Posted 16th Sep 2011 at 17:21
pete_rallye
Figured it must have been something to do with overheating, just surprising to see it! The pistons look in good nick, valves haven't been touching. The clean spots on the pistons aren't actualy clean, it's like a white residue. I think the white marks may have been caused by coolant on them burning off when running.
Lap of the 'ring
Posted 16th Sep 2011 at 21:10
matt_gti
What would the symptoms be, if any, when the above happens?, if the cracks are just across the water ways then I'm guessing not as the HG would seal it and there wouldn't be any running issues as such.
306 GTI-6
205 GTI-6 Project
205 1.6 GTI - RIP
205 1.9 TT - RIP
E39 535i - Daily driver
*Newest edition* E60 M5 5l v10 - The weekend car Smile
Posted 18th Sep 2011 at 00:40
Carl Chambers
lack of antifreeze in cold weather would cause that aswell
Carl Chambers
email; pugnacious.peugeot@yahoo.co.uk
C.M.CHAMBERS CARS
Peugeot Specialist
Tel; 01379 586101 after 6.30 or 07889 082466 anytime.
pugsport-racing.co.uk
Posted 21st Sep 2011 at 21:21
