Author Subject: Throttle body porting
cwspellowe
Aimed at Ash mainly but he's not a paid member so Dunno..
On the BTCC throttle bodies, have they only been ported pre-butterfly? Going off tobeski's thread here it seems like it's only the area around the IAT sensor that has been machined, hence losing the progressive first 1/3 of throttle control.
Considering getting the dremel out on a spare body. Spending that much time redesigning the inlet setup I figured it might be worth a few hours of grinding. Anything to reduce turbulence, right?
Also Mei, didn't you get one off someone a few years ago?
Bye bye Sundance Kid Sad
Posted 14th Sep 2011 at 00:21
nope, adam had one i think.
btcc cars didnt use stock tb's afaik, i thought they had to use a std size item for regs.
wouldnt bother faffing tbh, given its the same casting the v6 engine uses
Posted 14th Sep 2011 at 00:41
Agreed, its the diameters of the runners on the plenum and the valve throat area that are the biggest restrictions. Forget doing anything like that with a dremel though, you need a long series industrial die grinder or serious motor and a flexishaft whith a 2omm allicut burr on the end of it to be able to do the job in a sensible timeframe. Either that or slice the manifold in half which you have to do to get at it al properly anyway. But unless you have all the cams, valves, exhaust etc. uprated to match it won't help you anyway.
Posted 14th Sep 2011 at 08:56
Sounds like a man talking from experience Jim Whistle
Posted 14th Sep 2011 at 12:38
You could say that Wink
Its worth noting that any mods done to create more airflow will actually loose you power unless accompanied by a remap as the car will run leaner and make less power.
Posted 14th Sep 2011 at 14:09
cwspellowe
True davey, eveything up til now though hasn't created more airflow by mass, just better directed.
Bottom end and midrange torque feels hugely improved with the straight induction setup though. I was just thinking that a mild port/polish would be a good thing with minimum turbulence from the inlet tract
Posted 14th Sep 2011 at 18:38
honestly3k
Does your new air intake setup work well then? better than standard? I only ask because frankly it just looks laughable! LOL Flowers
Posted 14th Sep 2011 at 18:47
cwspellowe
Laughable? I hope you mean about the brown plastic pipe as that's long gone now!
Does seem to have made a difference, low RPM pickup seems much better, but no facts or figures I can throw at you.
Not finished yet anyway, still need to make the airbox and inlet duct Whistle
Posted 14th Sep 2011 at 19:00
matt_gti
When doing these sort of mods the biggest difference I think you feel is in the pick up on low revs. Will look at doing this on my 6 at some point but probably won't have the time or the tools to remove that much material. I did port a few 205 gti TB's with again the same differences in pick up.
306 GTI-6
205 GTI-6 Project
205 1.6 GTI - RIP
205 1.9 TT - RIP
E39 535i - Daily driver
*Newest edition* E60 M5 5l v10 - The weekend car Smile
Posted 14th Sep 2011 at 23:00
rich_w
It's a waste of time doing anything to the throttle body.
As others have said that's not where the restriction is, the air velocity is relatively low there compared to other areas of the engine.
I doubt the standard T/B would be the limiting factor in terms of peak power until your past 250 BHP.
In terms of turbulence - turbulance is good to get an even AFR accross the intake charge, and a consistent burn. Laminar flow won't properly mix the air and fuel, and is likely to have rich / lean areas within the intake charge, which won't burn as cleanly.
Smile
Contact Details:
07732 822546
Posted 15th Sep 2011 at 15:56
cwspellowe
Wait, having had a look at it today, I see why "throttle response is improved"... there's a stepped bit blocking half the butterfly up to 1/3 throttle, throttle response must only feel better as that progressive restriction is removed and more air gets in at part throttle. Doesn't make any difference at WOT from what I see.
Oh well.
Posted 15th Sep 2011 at 19:40
matt_gti
Doesn't turbulence happen mainly in the inlet as is enters the head and when fuel is added so most of the mixing is done just before the valves as it enters the cylinders?, hence it not being a good idea to 'polish' the inlets as the AFR won't mix properly.
306 GTI-6
205 GTI-6 Project
205 1.6 GTI - RIP
205 1.9 TT - RIP
Posted 16th Sep 2011 at 09:12
jimmyhackers
dead thread i know but....
after studying various air flow dynamics and other related literature after seeing that mighty car mods potato exhaust....i thought id weigh in after porting my own throttle body today (2+ hours with a dremmel)
big learning step for me was car engine airflow is pulsed....not linear...so some different rules apply.
1. Peirre must of made mine at 11:58 on a friday.
there are numerous steps/and shelves inside due to poor manufacturing, casting and machining, probably causing all sorts of turbulence. also, where the outlet of the TB meets the inlet of the inlet manifold...lined up by a blind man it would seem. not even close to centralised.
2.not sure if my inlet manifold hole has been widened in the past (there are linear chatter machining marks around its perimeter?) its inlet diameter is about 2-3mm larger than the exit of the TB, so some TB porting may help.
3. the narrowest/most restricted part of the whole intake system is the 60mm butterfly valve....the intake runner surface area in the inlet manifold when added up converts to more of a 90mm equivalent single hole, so its not there.
4. turbulence can effectively shrink that holes diameter dependant on severity. so any reduction in steps/turbulence around that area is probably more beneficial than you would imagine.
5. the TB hole is actually somewhat ovalled if you look directly through it. on the inlet side its restricted by the two lobes either side or the air temperature sensor...and on the outlet side its where the charcoal evap port lines exit, the actual body wall narrows/slopes in, which is a bit weird i thought...
6. knocking down those two high surfaces that make it oval adds a fair amount of extra surface area to its through hole area, probably 1-2cm squared... these two areas also choke airflow on partial throttle. i only knocked down the highest parts of the lobes closest to air temp sensor as they were what was ovaling it on that side, completely removing them would of taken probably another hour of grinding that i couldn’t be bothered with.
7. air/fuel mix is metered by the map and 02 etc....so extra air would be noticed by the sensors and corrected for. at WOT the gti6 ignores it all and dumps fuel in, running rich as it is...so id imagine the minimal air volume gains caused by this wont effect performance negatively in any way.
8. the map sensor is right behind the TB. reduction in TB turbulence should reduce wave pulseyness that the map sees which is a good thing. probably minimal effect though.
9. you could probably get another (1-2 cm squared through surface area) of material off the butterfly valve shaft, knife edging the plate also.......but im not that good (a fanny) and i only ground down the two screws extra protrusion out the rear.
10. the TB intake side front lip, not sure it its left over casting marks or by design, makes for a very sharp 90 face/edge for incoming air to smash against...especially as most of us fit a 76mm tube over it. i focused a lot on removing this and widening and smoothing/de-stepping the internal surface as much as possible effectively bringing its outmost ID as close to 76mm as possible. i also had a go at the front of the IAT lobes graduating it a bit more.
butt dyno says....engine induction note has changed, sounds a bit more uniform, bit louder and its slightly lower in tone... low and mid throttle response/pickup seems to of improved a fair bit. top end was always good but i can also feel some difference there.
theoretically.... the 60mm butterfly valves surface area is about 28.27cm squared, and depending on how well you port the TB... a 1-4cm squared increase in flow area is 3-12%. so power gains could be somewhere in the sub 3-12% range.
conclusion, fun, easy, quick-ish project, seemed to help.
if trying it yourself...i used a dremmel, small diamond cut/grind wheel, an 80 grit flap wheel, finishing with 120 grit paper by hand. i aimed too and successfully avoided all surface areas where the butterfly valve sits/interfaces at rest, DO NOT!! touch these areas.
go slow....thoroughly clean it afterwards with proper cleaning fluids and a compressed air gun.
Posted 3rd Oct 2026 at 16:00
