Author Subject: Handbrake Adjustment
kinger84
Alright fellas, im going to attempt this in a minute, is it easy to do or cock up? bloke at the garage said be carefull you'll bugger up the brakes?
Posted 12th Sep 2011 at 14:21
mark.evs
easy enough mate, tighten the 13mm under the center console till u have about 3 clicks on the hand brake, also after you've adjusted it make sure u can then spin the rear wheels freely (handbrake off), if they're tight u'll have to loosen the cable a bit.
My GTi6 track project
White Rallye project
Posted 12th Sep 2011 at 14:32
atterz
When i do this on my car one side locks up way before the other?
owain wrote:
Posted 12th Sep 2011 at 23:14
Probably a buggered handbrake cable and MOT failure then Yes
Posted 13th Sep 2011 at 08:20
mark.evs
Disconect the cables and make sure they move freely, if they do Try winding back both pistons, give the sliders a good grease and then pump the brake pedal up before adjusting the cable that should reset the calipers and hopefully sort your problem. They are a pain to get right and wat makes it worse is the handbrake is pretty poor design to start with.
Posted 13th Sep 2011 at 08:56
atterz
Cheers mate ill give it a go!
Posted 13th Sep 2011 at 20:07
