| Author | Subject: :'( oil in coolant |
judge dead
Regular Location: Scotland Registered: 30 Jul 2011 Posts: 397 Status: Offline |
since ive had my 6 its always went to 107 then cooled down but today it almost went into red so i got home and thought maby il check coolant only to find i had hot chocolate mix for coolant..... =/ but the oil has no signs off water in it any ideas? think its struggling to cool down due to the new coolant mix lol. like 2 weeks ago i resealed thermo stat houseing and coolant seemed ok then so it may have happend recantly |
cwspellowe
Seasoned Pro Location: Calderbank Registered: 19 Jul 2009 Posts: 6,496 Status: Offline |
Could just be corrosion in the cooling system, thought mine had gone as my coolant was brown sludge but was a rusty heater matrix clouding up the coolant. Flushed and refilled the system and it's fine now. Also had my cam covers off today and no emulsion to be seen so think my HG is ok for now.In your case though it may well have gone if it got to the red, by that stage it's too late usually and the residual heat still cooks it even if the engine's switched off straight away. Mine was getting hot but never overheated as such. ________________________________________ Bye bye Sundance Kid |
judge dead
i thought possibly oil cooler as its not gotten into oil yet but meh got any links to doing HG and on a scale of 1-10 how hard it is |
swiftyboi006
Need new water pump and timing kit, but takinh the head off and replacing the hg isnt too bad if you follow a guide on here. Look it up________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
darzmat
Senior User Location: nairn Registered: 14 Jan 2011 Posts: 879 Status: Offline |
and get your fans sorted aswell. fixed mine straight away as soon as they started switching on at 107 in stead of 97.________________________________________ 1997 blaze GTI-6 bought january '11 £800 Spend to date on parts £827.88 |
drop the coolant and bypass the heat exchanger, see how it goes, probably need to flush the system several times to get rid of the crud.if its not misfiring on startup or pressurising the coolant I'd imagine it'll be fine, seen a few heat exchangers go and you wont get waqter in the oil usually as the oil runs at a much higher pressure. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
swiftyboi006
