Author Subject: Bit of advice/quick response.
mattgti6phase2
Hi guys as I write this I'm sat at a car garage having my tracking done. Anyway last night my car decided that it did not want to start! What happens is when you turn the key it doesn't turn over and when turnin the key the battery light goes out then comes back on when you return the key towards you Crazy
I'm thinking is it actually the starter motor at fault or maybe a dirty earth/neutral terminal to the starter? My thinking behind this is because in my experience when a starter is on it's way out it makes a clicking noise on turning the key but mine literally does nothing.
Any advice would be great because the mechanic here is going to have a look at it and I'm not too clued up on starters and don't fancy being mugged off.
Thanks in advance.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 8th Sep 2011 at 08:56
mark.evs
It does sound like a starter or bad earth problem mate, mine done the same thing and i turned out to be a starter, loads of fun to get at it mind, manifold off i found was the easiest way, so labour might be costly.
My GTi6 track project
White Rallye project
Posted 8th Sep 2011 at 09:06
mattgti6phase2
Something tells me it's a wire issue at the starter. It doesn't click or anything Dunno
5 x a 306 owner!
Posted 8th Sep 2011 at 09:21
Mine did this earlier in the year and the starter seemed to short out the battery as the clock and radio reset. A new starter sorted it out
Posted 8th Sep 2011 at 11:36
mark.evs
mine didnt click either, just stopped working.
Posted 8th Sep 2011 at 12:52
mattgti6phase2
I think you guys are right. New starter it is Sad FML any ideas on price?
5 x a 306 owner!
Posted 8th Sep 2011 at 14:54
berger
Will it bump start?
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 8th Sep 2011 at 15:33
Mine had similar issues, turned out the nut which held the wire to the main motor had slackened off causing a poor live connection, bump started fine but was pretty inconvenient since i was at oulton park at the time LOL
Loctited the bugger in place now and its been fine since. Smile
Posted 8th Sep 2011 at 17:22
mattgti6phase2
berger wrote:
Will it bump start?
It will indeed. When it decides to not start you turn the key and the battery light goes out. That's what confuses me.
5 x a 306 owner!
Posted 8th Sep 2011 at 19:15
monkeyman
Try giving the starter a sharp tap with a hammer, it may just have stuck. Or put it in gear and rock it back and forth while stationary to loosen starter.
Forum Search Clicky
Posted 8th Sep 2011 at 20:39
will130787
Eeasy enough job to change the starter, as said above give it a knock with a hammer Wink
Ex Astor 6 owner Sad
Also an Ex owner of a Bianca 6 Sad
Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... Superman
Now driving Mk5 Golf GTTdi, mile muncher
But still live for the 306 Ninja
Posted 9th Sep 2011 at 10:19
mattgti6phase2
Never done it on a 6 and it looks a right ball ache. Got a new starter for £50 and my friend is banging it on there for me Thumbs up
5 x a 306 owner!
Posted 9th Sep 2011 at 14:17
ballardpaul
Doesn't the starter come out and attach to the flywheel when turned on so being in gear and rocking it won't touch the starter as it's not attached to the flywheel at that point?
The joys of a sc car. There ain't a manifold in the way so it's p*ss easy. Can imagine it's hard to get at on a normal one.
Nissan 350Z (300 BHP)
Posted 9th Sep 2011 at 16:13
Spot on, its the solonoid on the side of the starter that reacts to tapping, not the starter itself usually. And no, rocking the car back and forth in gear will have no effect on the starter motor at all as the bendix flies out and engages in the ring gear only when the starter motor is turning under it's own steam and disengages when the key is released (usually Wink )
Posted 9th Sep 2011 at 16:40
mattgti6phase2
New starter fitted £30 for a mate to do. Brand new starter £50 pretty well priced I think? Apparently my battery caused the starter to fail Dunno
5 x a 306 owner!
Posted 9th Sep 2011 at 23:11
cwspellowe
Dunno
Have a sinking feeling mine's packing in, went to start it today and it didn't click, just cut out. Ignition off then on again and it worked fine. Weirdness.
Bye bye Sundance Kid Sad
Posted 9th Sep 2011 at 23:18
mattgti6phase2
cwspellowe wrote:
Dunno
Check your battery? When I checked mine the cells were bone dry!! Resulting in a drop of ampage to the starter.
5 x a 306 owner!
Posted 10th Sep 2011 at 00:14
