Author Subject: big valve head
dav1
Thinking of having a Dave baker (puma racing) big valve head done. Ive got 220bhp an just thinking bout this would it improve power across the rev range? my engine is very camy an you have to work it. I don't mind this but wondering if this will improve power top end but help mid range. I would ask him but I bet he gets it all the time. I hear he's one off the best in the business.
230bhp 205 gti6
Posted 19th Aug 2011 at 00:12
matty_rallye
To be honest the gti6 head flows very well as standard and theres not a huge amount to be achieved when at 220-230 bhp.
2.1 16v 306 Rallye.
Posted 19th Aug 2011 at 01:10
valves are pretty big already!
best in the business? LOL
if you want best in the business go to france with lots of £££££....
what's the spec of your engine currently?
Posted 19th Aug 2011 at 01:40
dav1
45mm throttle bodies, Newman pH4's,omega hi-comp 87mm pistons,omex ecu,straight threw exhaust.
230bhp 205 gti6
Posted 19th Aug 2011 at 01:51
matty_rallye
What torque does the engine produce? Who did the mapping for you?
2.1 16v 306 Rallye.
Posted 19th Aug 2011 at 01:59
which inlet and exhaust manifold?
Posted 19th Aug 2011 at 02:24
mad scientist
If you are taking the above advice and going to France, I'd suggest you take €€€€€€€ not ££££££!
If you want a good job doing in the UK I'd personally advise you speak to Mark Shillaber. He'll let you know exactly what you can expect to gain flow wise. As others have said, your limits will depend on many factors. I doubt you will see much difference with those cams.
205 rally car with 2.2 hybrid 6 engine: phase 2 engine build underway.
Posted 19th Aug 2011 at 03:21
matty_rallye
Money could be better spent tho rather than trying to improve a head thats not really holding the engine back!
2.1 16v 306 Rallye.
Posted 19th Aug 2011 at 03:50
mad scientist
I agree, but I know what it's like chasing power!
Posted 19th Aug 2011 at 04:00
dav1
well wat do ppl do to get another 80 bhp from these engines? i know rpm is increased but surely they have head work. An no i cant just afford to go an get race engine built in one i have to do abit at a time. i run a longman inlet. torque is 157. mikeanics mapped it.
230bhp 205 gti6
Posted 19th Aug 2011 at 12:04
steel crank and bigger cams, proper exhaust and inlet, more revs.
oh and much more frequent rebuilds...
you can;t really do this a bit at a time and still run it, you need to get all the parts designed to work as a package.
Posted 19th Aug 2011 at 14:07
dav1
Well i got a longman inlet what other inlets are there pug1off don't run them sandy brown inlets on there 300bhp motor. I know the standard exhaust Mani can restrict but should t that go to 240bhp? Inst the crank in the gti6 steel? thanks
230bhp 205 gti6
Posted 5th Sep 2011 at 18:47
matty_rallye
Standard exhaust mani is restrictive at 230-240 bhp. Which is also pretty much the limit of where you will get with the cams that are available on hydraulic lifters. You will need solid lifters and more agressive cams to see anywhere near 300 bhp. Which will also require a decent maniflow manifold and 2.5" exhaust, 48 or 50mm tb's and a decent inlet.
I shouldnt worry too much about a headline bhp figure, have you seen the torque of the higher bhp pug 1 off engines?
2.1 16v 306 Rallye.
Posted 5th Sep 2011 at 20:21
dav1
Could only find one of the torque figures of a 275bhp engine an it was 175.
wat torque is yours running matt? mines 156 is that any good?
230bhp 205 gti6
Posted 5th Sep 2011 at 20:45
dav1
Just found it 301 bhp engine was 184 torque.
230bhp 205 gti6
Posted 5th Sep 2011 at 20:51
matty_rallye
Mines 176 lb ft. Hoping to get that up once mapped again as have changed to a maniflow and also 2.5" exhaust.
Have seen Sandy produce over 200lb ft from a 2.1 which was peaking at around 230 bhp.
2.1 16v 306 Rallye.
Posted 5th Sep 2011 at 21:23
dav1
that sounds good because i really have too rev the bo***cks out of mine. do you think selling my throttle bodies set-up an buying one of his will make good difference. I run a 2.5 exhaust just std manifold thow.
230bhp 205 gti6
Posted 5th Sep 2011 at 21:28
matty_rallye
It wouldnt be the bodies themselves, possibly just the inlet manifold. But the trumpets themselves can have an effect, some people play with different trumpet lengths when mapping to get the best overall result. I would doubt that you would see much more bhp but it may be possible to get more torque. Would be best to PM Sandy to be honest to see if he would be able to map your type of ecu, and if he can what he would recommend in terms of the inlet / trumpets.
2.1 16v 306 Rallye.
Posted 5th Sep 2011 at 21:37
dav1
Is he on here? thanks
230bhp 205 gti6
Posted 5th Sep 2011 at 21:53
matty_rallye
Yea, have a look through the members list.
2.1 16v 306 Rallye.
Posted 5th Sep 2011 at 21:56
