Author Subject: shaking through the steering wheel
167gti6.
Right i have real bad shaking through the steering wheel ( as if the wheels were not balanced properly)
Now i have had the cv done as the boot kept popping off therefore may have dried out, but still have the problem, Im now starting to think it maybe drive shaft, or wheel bearing, but i have no wheel baring noises :s
Any help would be grate before i go out and buy shafts and bearing.
lowered 55mm ish on race land shocks starting to wonder if they are responsible, Think i am going to change them aswell
Built not bought!
73k
Diablo ph2.5
Posted 18th Aug 2011 at 21:16
braymond
like you say - likely cause is wheel balancing! Are you running Cyclones? Notoroiously poorly balanced
Rallye-R
Nurburgring article
Posted 18th Aug 2011 at 21:23
167gti6.
Not wheel balance as its slowly getting worse,
i had my black clones on and it was doing it changed to my silver ones, still doing yet,
BUT my black clones are now on my dt and they are perfect not even a tiny wiggle of the steering wheel
Built not bought!
73k
Diablo ph2.5
Posted 18th Aug 2011 at 21:30
Any movement in the wheels when they are off the ground? Track rod ends and balljoints ok?
Which side CV? Is the middle joint on the drivers side ok?
The intermediate shaft bearing could have been buggered by the CV going. That housing can come loose from the engine too. There will be some movement in line with the engine (push/pull) as they float, but see if you can twist it by hand.
Could also be the clip holding the new CV on has failed and its coming loose from the shaft (had that before). I'd check that shaft.
Damping wear would show up mostly when you hit a bump, not all the time. Especially after some driving as the shock oil has gotten hot and stops working as well. (Hence don't use rubbish dampers)
Posted 18th Aug 2011 at 22:15
167gti6.
Adam b - Thanks for that mate! i will get it up in the air sat and have a good look all of what you have pointed out, seems like the obvious now you have pointed it out lol,
once again cheers bud! will report back sat
EDIT- also had the problem before cv change
Built not bought!
73k
Diablo ph2.5
Posted 18th Aug 2011 at 22:28
cornish_pug
I take it you're on cyclones?
I had this problem recently, above 50mph the steering wheel would shake like there was an earthquake. Got them balanced @ ats, now smoooooth Thumbs up
Team Diesel
Posted 5th Sep 2011 at 18:50
walker_texasranger
I had this on the HDI too, turned out to be warped discs that were slowly getting more warped LOL oh, and unbalanced wheels LOL
Hilux InvincibleX daily
306 No.13 Doh
Posted 10th Sep 2011 at 12:12
niw
Did you find a solution to this?
I have the same issue.
Posted 15th Oct 2012 at 09:07
