Author Subject: 406 gear stick
yadam
Ok so if I'm doin a 306 v6 convertion and I've been told that I need To use the 406 gearstick set up so I have bought 1 what I need to no is does the gear stick box have to be welded in side the car as it does not fit in the spaces were the exhaust runs but I was thinking I could cut the heat shield and make sum sort of mount. What does every 1 eles do thanks
Posted 18th Aug 2011 at 18:51
remove the heat shield, bit of trimming and it bolts on, wont be able to weld it, its alloy...
Posted 18th Aug 2011 at 23:09
yadam
Yea Ok thank you
Posted 19th Aug 2011 at 01:26
