displaying posts 1 to 2 of 2
Author Subject: Emerald wiring loom sensors
thelegendofando
I'm currently trying to wire up my ECU but Emerald's wiring diagram only specifies two wire for both my crank and cam sensors. However, the gti6 has three wire (digital) sensors.
I know the sensor wires are:
-Signal wire (ECU pin specified)
-Ground signal (ECU pin specified)
-5v feed (nothing mentioned)
I know the Emerald has a 5v feed out from pin 9 but I wanted to know if anyone else has used pin 9 or if they swapped to inductive sensors?
205 GTi6 - work in progress
Posted 13th Aug 2011 at 02:00
thelegendofando
Actually, might have just worked it out! Emeralds manual says to wire it to pin 14 but that's for an older version ECU than mine. I'm sure my diagram doesn't say that but I'll check in the morning.
Posted 13th Aug 2011 at 02:24
