Author Subject: Still no brakes!!
poogiepug1
A few weeks ago i posted that my break pedal just goes to the floor, after the suggestions i had a new master cylinder fitted and a new valve thing with the little rubber cover (inside engine bay left of the battery and up a bitLOL)
The brakes are better but it still goes pretty much to the floor but if i pump the brake pedal once then it brakes sort of like normal. suggestions pleaseSmile
Posted 8th Aug 2011 at 17:04
mark.evs
sounds like they need bleeding mate. They can be hard to get the air out due to the bias valve on the axle.
My GTi6 track project
White Rallye project
Posted 8th Aug 2011 at 19:15
poogiepug1
They were bled but cant harm to do again. Cheers
Posted 8th Aug 2011 at 20:47
tvrfan007
Bleed again as above. Bleed til you're happy with the pedal.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 8th Aug 2011 at 21:01
Check your compensator on the rear beam is free/not seized before bleeding.
Posted 9th Aug 2011 at 02:39
poogiepug1
I had that done to, so must need bleeding. Fingers crossed
Posted 9th Aug 2011 at 05:19
tvrfan007
If you have ABS take it somewhere with gravel or similar loose surface and activate it a good few times before bleeding.
I'm Si btw Tee hee
Posted 9th Aug 2011 at 11:11
poogiepug1
Thanks for that, didnt realise it made a difference on the surfaceSmile
Posted 9th Aug 2011 at 15:01
