Author Subject: Trailing arm press
pete_rallye
Anyone on here pressed the pin out of the trailing arms themselves? If so, what size press did you use?
Thanks!
Lap of the 'ring
Posted 8th Aug 2011 at 02:41
yup, 20 ton one sufficed, I think the most I've had on one was about 8 tons though.
I take it you mean the shaft the arm moves on? the one the bearing sits on can be knocked out with a copper hammer easily enough.
Posted 8th Aug 2011 at 02:50
pete_rallye
Nice one, yeah I mean the big pin the ARB passes through. 20 ton one it is then.
Lap of the 'ring
Posted 8th Aug 2011 at 02:59
allanallen
My 10 tonner's never let me down.
Facebook
Posted 8th Aug 2011 at 03:17
pete_rallye
12 ton one on ebay for less than £100, ideal! Should handle most things hopefully!
Thanks guys!
Lap of the 'ring
Posted 8th Aug 2011 at 03:19
should cope with wheelbearings just fine too Smile
Posted 8th Aug 2011 at 15:48
idnan
slightly off topic but would a 10 ton press be enough to remove and insert bushes similar in size to the lower gearbox one?
Posted 8th Aug 2011 at 16:31
Rich E Forum Admin
Yes, but having a press only gets you half way there.
You still need to find / fabricate / improvise tools that fit the things you want to press.
Posted 8th Aug 2011 at 17:51
pete_rallye
Just for info-
I bought a 12 ton press fom KMS on ebay for £109 delivered. It was delivered next day, and its ermmm, well, it works. It comes flat packed and it goes together easily enough, with a little persuasion. Lets just say the holes may as well have been drilled by Stevie Wonder.
Its basically a bottle jack, built into a frame. I have managed to press the big trailing arm pin, the rear wheel bearing (without damage!) and the stub axel out of the trailing arm so its done me ok. I don't think it will ever pass any health and safety tests and it wouldn't cope with proper garage use but for the average home garage it is a cheap way of doing stuff yourself! You will need to fabricate a few bits n bobs, but I managed to press all the bits mentioned above out using the plates that come with the press, the removed pins, a long 17mm extension ad a 32mm socket, so not too bad!
All in recommended, but bare in mind its cheap for a reason!
Lap of the 'ring
Posted 12th Aug 2011 at 03:22
Had often wondered how good those cheapy ones were, well worth knowing Yes
Is it one that attaches to an air compressor, or one with a hand pump jobby?
Posted 12th Aug 2011 at 16:54
pete_rallye
Nah, its a hand pump jobby. Added bonus is that you can remove the bottle jack and use it seperately if you wanted too!
Lap of the 'ring
Posted 12th Aug 2011 at 17:12
Cheers and noted Thumbs up
Posted 13th Aug 2011 at 00:32
