Author Subject: bolts won't tighten !
daddy5times
any help appreciated the bolts that hold the thermostat to the engine won't tighten up . It's like they have been over tightened . Does anyone know if there's anything I can do to sort or ?????
Posted 7th Aug 2011 at 23:17
Remove them, if you're lucky you've ripped the thread off the bolt. If you're unlucky you're stripped the thread from the casing.
Posted 7th Aug 2011 at 23:29
daddy5times
Done that bolts look fine is there something I can put in with the bolt something that sets ??? Then maybe they will tighten cheers
Posted 7th Aug 2011 at 23:44
You can get thread repair kits, but you'd probably be better replacing the thermostat housing if it's a part that comes off easily, can't really picture it.
Posted 8th Aug 2011 at 00:08
daddy5times
Bolts go through housing into side of engine .where would I get thT repair stuff from??thx
Posted 8th Aug 2011 at 00:43
Sounds like you have stripped the thread in the head ? a thread doctor could prob fix this with a heli coil but doubt it can be done in the car ?
Could always try some thread lock and do up the bolts as tight as they will go before they loosen again ? Not sure you will get a good seal they and it will porb leak coolant
Posted 8th Aug 2011 at 01:37
daddy5times
Cheers that's the problem it is leaking a little coolant not a lot but it's still there I'll try some thread lock thx pal
Posted 8th Aug 2011 at 02:03
