Author Subject: ET35 and ET40
dohcturbo
Hey,
I have 17inch 4x108 alloys,
Two wheels with et35 and two with et40.
Will these fit the 306 straight?
If so, which et goes where?
OR
If not, what size hubcentric spacers will i need for the front? and/or will i need them for the back?
Very confusing i know. Smile
Any good info to sort this out, thanks.
Posted 7th Aug 2011 at 22:40
youll need spacers for both pairs, depends how wide they are but a 20 or 25mm spacer for both would be reqired
Posted 7th Aug 2011 at 22:41
dohcturbo
Thanking you,
I would imagine the 17x7, i cant see it written on them.
Will the standard cyclone bolts work with the 25mm spacers? or would i need standard 306 bolts?
Are the bolts used on the cyclones longer than the standard 306 bolts?
Posted 7th Aug 2011 at 23:16
cwspellowe
I wouldn't use standard bolts at all with that size of spacer, my Speedlines are spaced 20mm and the standard bolts barely reach the hubs!
Bye bye Sundance Kid Sad
Posted 8th Aug 2011 at 01:21
dohcturbo
So spacer size and wheel bolt size is what iv to sort now.
These are the 25mm spacers, are they the right ones?
http://www.performancealloys.com/spacer-details.aspx?ID=7381
Or will i use the 20mm spacers?
And what length wheel bolts for 20mm and 25mm?
Link if anyone has one.
Posted 8th Aug 2011 at 05:03
