Author Subject: Calling all Tran x LSD gurus!!
judley
Hi guys. Just fitted a new Tran x plated LSD a couple of weeks back and it's making some very weird noises. Please listen to the first 30 seconds or so of the car reversing out of the pit garage and then turning onto the pit lane. Is that sound normal? I have to say the diff works great round corners and makes no noise in the straight ahead position. It just sounds like it's tearing itself apart when in slow speed corners (not under load) like in the video.
Anyone else have similar issues?
http://www.youtube.com/watch?v=21heF-ZRVb8
Posted 3rd Aug 2011 at 21:57
allanallen
I can't watch the video as I'm on a phone but they can be noisy.
Is it new and what ramp angles/preload is it set at? What box oil are you using?
Al
Facebook
Posted 3rd Aug 2011 at 22:05
Pretty sure plate diffs make a bit of noise in situations like that.
I have heard people say things about their plate diffs clunking about while parking etc, but fine when driving.
Posted 3rd Aug 2011 at 22:10
judley
Al
It's a 30/60 Ramp Angle Lightweight model mate. I'm using 80w90 LSD oil but not the Millers CRX LS 80w90 NT as I had to refill after draining the expensive stuff Angry
Would the Miller NT oil really make much difference?
Posted 3rd Aug 2011 at 22:21
allanallen
I run standard (comma) 75w80 oil in my boxes, nothing fancy at all.
If the diff or the plates are new or even if they've been refitted in a different configuration you need to change the oil after it beds in (50 miles or so). My brothers tran x was considerably quieter after an oil change.
All our diffs are at 45/45 and are virtually silent, 30/60 will defo be more 'snatchy' and noisy though.
Al
Facebook
Posted 3rd Aug 2011 at 22:29
judley
Al
Cheers Alan, so my 30/60 is more aggressive than a 45/45? I thought it was the other way round LOL
Any other guys with Tran x LSD care to listen to the clip and comment please?
Cheers,
George
Posted 3rd Aug 2011 at 22:41
allanallen
Yours will be more aggressive on acceleration and less on deceleration. In theory your set-up should be better for track use mind.
Facebook
Posted 3rd Aug 2011 at 23:12
pete_rallye
Millers LSD oil is designed for dog engagement boxes. If you use it with syncro boxes you'll likely knacker the syncros pretty quick.
I've got a plate diff albeit a peugeot sport (ZF) one and it is a little bit noisy but nothing major. It isn't new by any stretch of the imagination though. It feels really strange when you're driving slowly though...
Lap of the 'ring
Posted 3rd Aug 2011 at 23:16
judley
Cheers Pete. The Millers CRX LS is recommended by Tran x, that's the only reason I mentioned it. Not cheap at £40 a refill either. Did you listen to the diff in the clip as I'm trying to get a feel for what is acceptable and what's not?
Posted 3rd Aug 2011 at 23:18
gti6girl
I take it it's in the 205?
We had some trouble with the tran x in a 205. Webhad to change the plates round for the softer setting, think it's teeth,washer,teeth,washer,teeth or something like that we also put it back on 45/45, it's now very quiet where as before it was undrivable
Posted 4th Aug 2011 at 03:16
judley
It is in the 205 mate. Did Tran x make the change under warranty?
Posted 4th Aug 2011 at 03:22
gti6girl
No it's something you need to do.
Mine was supplied 30/60 with the plates teeth,teeth,washer,washer,teeth
This would be fine on a 306 with power steering but me and my mate put it in without reading the instructions
We took it straight back out opened it up and set it on the other settings, now it's awesome
Posted 4th Aug 2011 at 03:32
allanallen
That's 30/60 lightweight with the plates like that.
Teeth,washer,teeth,washer,teeth is fully intervaled ie; maximum locking force.
Al
Facebook
Posted 4th Aug 2011 at 03:39
gti6girl
You are correct, it came like that and we set it to the other. I was going from memory from 6 months ago Smile
Posted 4th Aug 2011 at 04:09
clen666
So would a lightweight diff be manageable on a 306 with pas removed?
Team 'unintentional rat look'
Posted 4th Aug 2011 at 04:11
miles
As said, the Oil recommended isn't best at all, The pug Syncro hub's are very fragile with the wrong oil and can wear out in no time at all/Melt like I've seen quite a few
Noise wise should only be on lock at parking speeds, nothing else.
Oil wise I stick with the normal 75/80 which is what the box likes, Yes the diff may not work 100% but it's catch 22, But having sold and fitted quite a few with this combo all good so far over 3 odd years
www.pugracing.com
Posted 4th Aug 2011 at 06:36
judley
Thaks for all the replies guys, I appreciate it. I have spoken with Tran x this morning and it sounds like they have heard a similar story on many occasions and there's nothing to worry about.
I'm going to have it removed for an inspection anyway for my peace of mind. Tran x also recommended a heavier oil to quieten the LSD hopefully. They recommended a 75/140 rather than the 80/90............
Posted 4th Aug 2011 at 19:57
