Author Subject: 306 v6 clutch
yadam
Ok so I'm trying to finish putting a v6 in my 306 I'm stuck on the clutch as my car has a cable clutch were my 406 v6 has a hydro clutch what do I do the engine I have is a 406 3.0 v6 1998 any help would be very apreseated.
Posted 3rd Aug 2011 at 21:28
miles
Make a converter up with a master cylinder, Quite simple but takes a while to get the angle's and mounting point sorted,
Cannot say much more as it took me a couple of attempt's to sort it
www.pugracing.com
Posted 4th Aug 2011 at 06:31
yadam
Could u upload a photo to give me sum help
Posted 4th Aug 2011 at 16:00
miles
Never took any I'm afraid
www.pugracing.com
Posted 5th Aug 2011 at 03:08
andy306gti
Probably something like this is what you're looking to knock up.
The Picture is borrowed from This thread...
Posted 5th Aug 2011 at 04:01
yadam
Is that the other end of the hyrloilc clutch
Posted 5th Aug 2011 at 04:34
andy306gti
Yes, that would be the master cylinder.
Posted 6th Aug 2011 at 18:13
yadam
Hi befor I try nd mate the clutch thing in the photo above, I was think could u gt a 406 v6 pedal box and weld in place has any 1 tried this. Thanks
Posted 31st Oct 2011 at 08:39
Its VERY big! also the servo is remotely located on the left of the engine bay, probably possible but too much work IMO.
I think there's probably enough space to fit a slave in above the pedal or even the same position as the 406.
Posted 31st Oct 2011 at 11:09
Or just work out a way to get the cable to move the arm as we did. Proper faff though - extended it up through the top nylon bush, pinned the fork and welded an arm on. Was then an arse to get the pedal travel enough to make it work. Never did quite get it right, although managed 5k on it.
Wonder if any PSA cars use cable clutches with these boxes - you know I never even looked!!
Posted 31st Oct 2011 at 12:53
on the older ME yes, but not the ML Sad
edit, oh yes they did in the Boxer with the ML5T Big grin clutch shaft pokes out the bottom of the box! Big grin
don't think the v6 bellhousing has that cast into it, but shouldn't be difficult to modify, though I'd be weary of hanging a cable under the box on a 306, not such an issue on a boxer van.
Posted 31st Oct 2011 at 13:15
yadam
Adam did your clutch look like the setupin the photo then
Posted 31st Oct 2011 at 15:05
nope
Posted 31st Oct 2011 at 15:16
ORLY??
The sump/PAS pipe was the issue not the gearbox and we could have hoiked the coilovers up 15mm LOL
Someone say sump guard....?
Posted 14th Nov 2011 at 11:11
Hmm guess so, the whole thing sat quite close didnt it LOL
Posted 14th Nov 2011 at 11:38
Very close to speedbumps LOL
Posted 14th Nov 2011 at 11:44
