Author Subject: Hesitation problems
vincemasi
i am currently havin problems with my 306 2l xsi.
when i drive it to work in the morning it seams fine, but when i drive back in the evenings after about 45 min it starts to hesitate.
the problem starts with the car holdin back and loosing speed (70mph) when i put the foot down picks up power again. the engine management light comes on briefly then goes back out. at times the revs bounce on idle rather than stayin on 800rpm.
i am thinking it could be the MAP SENSOR?
Also had a diagnostic check carried out but no fualts are present.
any ideas?
Posted 3rd Aug 2011 at 17:49
mattgti6phase2
Lamda?
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 3rd Aug 2011 at 19:30
vincemasi
could be mate. i have ordered a throttle position sensor a map sensor and the lambda sensor will change one at a time and see what happens.
if all that fails then maybe coilpack and fuel pump.
really dont know whay to think as the ecu did not log any faults.
Posted 3rd Aug 2011 at 19:36
mattgti6phase2
Sometimes they don't log the faults though if they are intermittent. For example icv faults don't show on diag.
5 x a 306 owner!
Posted 3rd Aug 2011 at 21:03
woody.
I have a similar problem and replaced the lambda sensor which made no difference unfortunately :>>
Can you update this thread if you cure the problem?!?
Posted 9th Aug 2011 at 00:02
vincemasi
added a new tps but no joy last night. have removed the tps for the old one and fitted a new map sensor. will let you know how it get on tonight.
Posted 11th Aug 2011 at 14:05
black 6
Could be a coilpack playing up. Does it run badly when idling? If so what you need to do is one at a time remove the electrical plug from each coil pack. When you pull the connector the engine note will change. If you unplug one and there is no change you have found the culprit Thumbs up
Although it's no longer available new, it's worth trying to get hold of a good example second-hand. As GTi's get tubbier and cooler, it's nice to remind yourself of why insurance companies hate hot-hatches so much.-Top Gear on the 6 Apr '01. Black 6
Posted 11th Aug 2011 at 15:37
