When I first start the car from cold, it starts fine, idles fine etc. Once I start off, after about 30 seconds the engine starts to lose power, as if I've just pulled back off the accelerator (but I havent). If I keep the accelerator exactly where it is, the car slows right down, revs drop, and then after a second or two it picks back up and doesn't do it again.
I had a new lambda sensor fitted a bit back (for another problem) so I know it's not that.
I've tried it with the map sensor disconnected and it still does it, so I'm guessing that's not that either.
Any ideas anyone?
padge
I LIVE FOR THE 306
icv only controls the idle. If the power is fading away then it could be the TPS it may think it's shut when it's open
