displaying posts 1 to 25 of 37
Author Subject: S16 Temperature Headache!!!!
marcello
This pug has taken my wallet right out of my pocket and swallowed it
The car has been overheating towards the 110 degrees and never used to do this
So i took the thermostat out, put in a boiling hot water , and it opened up. So that wasn’t the problem ?
Bottom of the radiator was leaking we found so i replaced it with a brand new one
Now the car still overheats
There are no leaks what so ever
I don’t have to ever top up the radiator with coolant as it stays its level very nicely
i have bleed the system numerous of times and still no result
I have no idea what is going on
Here is a video of what is happening to me on idle - http://www.youtube.com/watch?v=98wXuEPyxXY
Any ideas people?
thanks
Posted 1st Aug 2011 at 07:39
kiwibrick
One of your cooling fans has stopped working for some reason, so you have no low speed fans and only one fan when the high speed kicks in (normally at 107deg) I would guess.
ph2 GTi-6
Posted 1st Aug 2011 at 13:20
marcello
thanks for the reply
are these low speed fans the thermo fans?
because the thermo fans havnt been kicking in at the normal temp? they tend to come on at 110 degress but the car doesnt get cooler it just stays on 110 Sad
Posted 1st Aug 2011 at 14:16
ballys16
Any ideas people?
thanks
If you have an AC then you have a brown sensor.
When ignition is off, unplug it and put ignition back.
What should happen is that the low speed fans come on (both) for ~2 secs and then both should turn to full speed and stay on. Any other type of operation points to a fault. Again, if you have an AC.
My car (P1 S16) had the same symptoms when the right fan was knackered - fan motor was replaced.
XSi 8V -> S16
Posted 1st Aug 2011 at 14:17
ballys16
Looking at your vid it does seems odd that when the high speed fans should kick in they don't seem to but what does cools the engine only a bit.
You sure bleeding was done well? Also, do you know for sure that the water pump is OK? Rad cap?
XSi 8V -> S16
Posted 1st Aug 2011 at 14:23
405gti6
Same problem when car is moving?
XU10J4RS powered 405 Big grin.
Posted 1st Aug 2011 at 14:47
marcello
Any ideas people?
thanks
hi mate thanks for the reply
when u say AC u mean air con?
also where is this brown sensor located so i can test . thanks
see i dont know if my fans are knacked because when at 110 they both come on
Posted 1st Aug 2011 at 14:55
will130787
Low speed fan not kicking in, new fan unit in my book Smile
Ex Astor 6 owner Sad
Also an Ex owner of a Bianca 6 Sad
Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... Superman
Now driving Mk5 Golf GTTdi, mile muncher
But still live for the 306 Ninja
marcello
Well i tried my best with the bleeding , there is definetly no air.
also how can i test the water pump to be sure?
and the radiator cap also changed recently to a new one
thanks for your help
Posted 1st Aug 2011 at 14:57
marcello
Hi mate
when the car moves the temputure goes down, but very slowly
normally the my s16 use to sit around 90-95 on idle
Posted 1st Aug 2011 at 14:58
ballys16
Yes, by AC I mean aircon.
The brown plug is near the thermostat housing only at the back of the engine, in line with the blue CTS. Can be just accessed.
BTW, if you turn on the AC, do any of your fans come on?
Water pump: are all water hoses ~ the same temp (feeling)
Oh, and by the way, if unplugging the brown sensor changes the way fans work then the sensor itself is at fault ~30 pounds and a spanner Smile
XSi 8V -> S16
Posted 1st Aug 2011 at 15:25
marcello
is this the brown sensor your talking about?
because if it is , i took it out and turned igintion on and nothing happend
also when i turn aircon on both fans start
Posted 1st Aug 2011 at 15:44
ballys16
Sorry, cant make out what I see.
Let me take a few pics of mine.
XSi 8V -> S16
Posted 1st Aug 2011 at 15:55
ballys16
Small, sorry, but here you are:
XSi 8V -> S16
Posted 1st Aug 2011 at 16:04
marcello
im so stupid i cant find it,
can u tell me what section it is? on this pic
[URL=http://imageshack.us/photo/my-images/35/photo0440p.jpg/
Posted 1st Aug 2011 at 16:20
ballys16
What you see (blue plug) is the thermostat housing.
That is on the left side of the car (left meaning if you sit behind the steering wheel), accesible from the battery side. It is ~ in the midle of the cylinder head, below the vacuum pump. The blue CTS is visible in both pics for reference.
Can you repost the pic? Dont see it.
XSi 8V -> S16
Posted 1st Aug 2011 at 16:44
ballys16
Got the pic finally.
So.
It is in the green section, accessible from the blue section.
Mind you, it is way below what your photo shows, taken from above.
That big alloy thing in the middle of your pic (on the border of blue/green) is the vacuum pump, visible in my pic. Below that really.
XSi 8V -> S16
Posted 1st Aug 2011 at 16:57
marcello
thanks for your help , but i have looked top to bottom of my car and lol i cant see it anywear
i can only find a green CTS on the side of the thermostat housing Sad
Posted 1st Aug 2011 at 16:51
ballys16
So.
That big allow thing in the middle of your pic (on the border of blue/green) is the vacuum pump, visible in my pic. Below that really.
XSi 8V -> S16
Posted 1st Aug 2011 at 16:53
ballys16
Do you have air conditioning? Because the brown sensor is available in the AC version only. Although you say you have a double fan setup (usually meaning an AC is there) it could be a "custom" feature.
XSi 8V -> S16
ballys16
Two guys down under:
> Him <
> and him also <
XSi 8V -> S16
Posted 1st Aug 2011 at 17:06
marcello
ballys16 your a champion i finally found it ,
i did what you said and this is what happend
Turned ignition on
Only left hand thermo fan operates at full speed
What should i do ?
thankyou mate sorry it took so long Smile
Posted 9th Aug 2011 at 08:34
marcello
Please watch this to see what happens to me Smile
http://www.youtube.com/watch?v=baAiYHmu2d4
Posted 9th Aug 2011 at 13:46
ballys16
Looks a bit odd, things going haywire... Smile
Relays OK? The 3 you see between the fans.
Next I would check the "bitron" unit under the left wing, right about where the horn is, brown box, about the size of maybe two cigarette packs (I mean replace it with one that is defo good) - this is the easier job.
And apart from the wiring all thats left is the fan motor itself - mine was replaced because the original sometimes came on and then sometimes didn't.
Also, if the fuse was to be blown the fans would remain on for a couple of minutes after shutting the car off - but might be worth a check.
XSi 8V -> S16
Posted 10th Aug 2011 at 01:50
marcello
ok so i changed all the fuses and relays
i checks the biton unit, that was perfectly intact and all pins where beauitful
when i turn ac on both fans come on
when car reaches 110 degress both fans come on
this is doing my head in lol
Posted 10th Aug 2011 at 18:47
