Author Subject: 87mm pistons
thelegendofando
I'm getting really confused over bore sizes and I suspect the answer is simple.
I've bought some 87mm wossner pistons, is it the bore that is 87mm or the actual piston?
In other words, what do I tell my engineer to bore it out to?
205 GTi6 - work in progress
Posted 23rd Jul 2011 at 00:16
Give the piston and the block to the engineer he will do the rest Wink
Posted 23rd Jul 2011 at 00:18
thelegendofando
I did but then he shouted at me for not knowing what size to bore it to :s
Posted 23rd Jul 2011 at 00:29
marksorrento205
Surely he should know or be able to find out the limits and clearances etc? If not maybe try somewhere else?
Try pm'ing Pete. He is in Stoke and has had the same work done. click here to pm him
Posted 23rd Jul 2011 at 00:47
thelegendofando
Well he said he will try and find a spec sheet for them and let know on moday, so I'll wait until then. Just wanted to know if its the incredibly obvious 87mm or if I'm missing something.
Posted 23rd Jul 2011 at 01:02
maddriver9
were you having it done i had mine done at Dave rushton in smallthorne an he worked it out it's all to do with how much the piston expands wen hot the skirt expands less than the top of the piston due to material been different thickness's.
178bhp 205gti6
¼ mile in 14.2
Posted 23rd Jul 2011 at 01:15
thelegendofando
I'm having it done at Dave Rushtons lol yeah he said all of that but I'm a good customer of his so he likes to give me some stick when I get something wrong! I originally told him to bore it to 87mm but then I got confused about if the pistons were 87 or the bore was 87.
Posted 23rd Jul 2011 at 02:14
allanallen
I would imagine it's for an 87mm bore, the piston should measure a bit smaller.
This should be fairly obvious to an engine machinist?!
Facebook
Posted 23rd Jul 2011 at 02:15
dav1
I had mine done there, he did good job.
230bhp 205 gti6
Posted 23rd Jul 2011 at 03:25
thelegendofando
dav1, you keep appearing in my threads! it's a bit creepy Razz
Posted 23rd Jul 2011 at 03:30
dav1
that's cus I done it all before you.Smile
230bhp 205 gti6
Posted 23rd Jul 2011 at 03:45
