Author Subject: cause of incorrect timing
tom97gti
I think my engine is still suffering from a tapper.
The head has been brought away for revision four months/5000 miles ago and new cambelt was fitted.
From start-up (after assembly) it's already been tapping. First I thought the hydraulic lifters were filling itself but after a couple of minutes driving it, it was still tapping. All the lifters and tappets were changed last year so the problem wouldn't lie there.
I think the machine shop and the mechanic both did a good job so I think the problem would be a failure of one of the cambelt parts.
What frustrates me that we used the latest cambelt set and also the waterpump has been changed.
Could the crankpulley or campulley still slip/jump a tooth? And if it slips it would slip all the time doesn't it?
So what I would like to know, what issues can mess up the timing when it was correctly timed at the assembly?
Posted 20th Jul 2011 at 16:44
the pulley can slip placing the pin hole and therefore the orientation of the crankshaft+pistons wrongly, if this was not noted during assembly then it will be incorrectly timed up and valve to piston contact is quit likely.
also turning the camshaft independently can bend the valves as they will strike each other due to their large sizes.
quite unlikely to be much else bar poor machine work when rebuilding the head, i.e not checking the valve seats or guides, or the valves
Posted 20th Jul 2011 at 16:47
tom97gti
Thanks for the fast respone Smile!
So the timing can only be off during the cambelt assembly?
It can not happen when first starting, running the engine or driving the car?
video of the engine here
Posted 20th Jul 2011 at 21:59
Slipped crank pulley or guides in the head need changing ? or still get a very slightly bent valve Wink
Posted 20th Jul 2011 at 23:08
