Author Subject: aem wideband lambda gauge
im looking at this on e bay: aem
is it the right on i need?
do i remove my original lambda for this one or is it better to have an extra boss welded on and use this one just for the gauge?
is there any advantage to performance running the wideband and ditching the narrowband, does the ecu then listen to it at all engine loads/rpm unlike the narrowband?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 20th Jul 2011 at 15:31
1 yes fit it in place of the original sensor
2 they are said to give a finer degree of control over the signal, but it doesn't change when the ecu uses the signal as that's down to the ecu software
Posted 20th Jul 2011 at 16:51
Thanks
Posted 20th Jul 2011 at 17:19
ive just read the f&q thread for these and its confused me slightly, it says to tie the narrowband lambda sensor up behind the battery tray to stop it giving a temp fault and to use a resistor aswell.
do i really need to do do this?
i thought it was just a case of fitting gauge and new lambda.
Posted 26th Jul 2011 at 15:50
smegal
THEY WON'T WORK IN PLACE OF THE ORIGINAL*.
*At least I couldn't get mine to. It kept flagging errors up on the diagnostics.
I found that when I lifted off the throttle the AEM went blank as it couldn't take a reading, this in turn upset the ECU.
You may be able to change the settings on the AEM but I never did.
Ex SC-6
Now in a Megane R26
Posted 26th Jul 2011 at 18:39
Did you weld on an extra boss then and use both lambdas? the standard lambda for the ecu and use the wideband for the gauge only.
Posted 26th Jul 2011 at 20:56
mcfc1987
that's what i did
Posted 26th Jul 2011 at 22:09
ballardpaul
Yeah all three of us had these problems, which was a big shame mine is still the only lambda used in my car thats because it doesnt hestitate in the summer for some reason. As soon as it starts happening again, when it gets cold I will probably weld in another boss.
Mabz didn't have this problem, so unless we fitted ours wrong.
Nissan 350Z (300 BHP)
Posted 26th Jul 2011 at 22:47
So when I do this I'm better off just welding In another boss and running both lambdas?
Thanks oh is there anything else I might want to know?
Thanks buzz
Posted 26th Jul 2011 at 23:33
ballardpaul
Na that's pretty much it. There's a FAQ on here of how to fit one. Maybe try it first without the second boss to see if you can get yours to work.
Posted 27th Jul 2011 at 01:38
smegal
that's what i did
Me too.
Ex SC-6
Now in a Megane R26
Posted 27th Jul 2011 at 19:19
ballardpaul
Finally got round to change the setting on the back of this gauge to P03 and it makes the car run lovely. No stuttering or hesitating, so all good so far.
I think I need to try the others to see whether this is the best mode, as some of the numbers are different to what P04 were. Not sure if this is a bad thing or whether I was just use to the digits I saw on the gauge before.
Posted 8th Aug 2011 at 14:30
I don't like the sound of this giving car running problems, Im having second thoughts.
Posted 8th Aug 2011 at 14:57
mcfc1987
just do what i have done, get a second boss on there and just use it as something fancy to look at
Posted 8th Aug 2011 at 15:37
ballardpaul
P03 has no running problems. or ask Mabz, as it seems like his works perfectly fine on the standard ecu.
Posted 8th Aug 2011 at 17:41
Think I will just use the extra boss and have the wideband just for the gauge
Posted 9th Aug 2011 at 01:45
But it would be better to read what the ecu reads
Posted 9th Aug 2011 at 01:52
smegal
When I get a minute I'll do the same and see if I get the same result.
Ex SC-6
Now in a Megane R26
Posted 9th Aug 2011 at 03:09
ballardpaul
Cool let me know. See if it still flags up faults on your diagnostic. I'd like to know if I'm doing any damage having it on this setting Dunno
Posted 9th Aug 2011 at 16:50
smegal
If it is reading ok then I doubt it is to be honest.
When you boot it what AFR readings do you get?
Ex SC-6
Now in a Megane R26
Posted 9th Aug 2011 at 18:24
ballardpaul
Between 12-13
Posted 10th Aug 2011 at 15:16
smegal
Hmm. Mine is running REALLY rich then. I get 9ish. No wonder my cats keep getting f*cked.
It may be time for my bigger restrictor ring.
Ex SC-6
Now in a Megane R26
Posted 10th Aug 2011 at 16:30
ballardpaul
Yeah it was at 12-13 even on the old setting. Custom remap!!! Ninja
Posted 10th Aug 2011 at 16:43
I thought the higher the richer.
Posted 10th Aug 2011 at 18:34
