Author Subject: Help! Rear caliper not winding in!
cdgray
Just doing my rear pads and discs and the caliper isn't winding in as it should. I'm turning in clock-wise but it doesn't move at all.
Does this mean the caliper has had it or is there some method to make it retract?
Chris - Phase 3 Moonstone GTi 6
Posted 16th Jul 2011 at 04:07
tvrfan007
If it's right out try applying some light pressure + turning as it may have unthreaded.
Ford rear calipers need pressure + turning!
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 16th Jul 2011 at 11:25
mpieczko
When I did mine I slackened my handbrake cable right off at the adjuster nut under the centre console trim cover.
Have you tried this? Mine wound in without any problems whatsoever. You will probably want to re-adjust the handbrake anyway so it's no extra work.
Posted 16th Jul 2011 at 21:29
colgti6
when u change the rear discs and pads on the gti6 do u need to change the bearings as well
Adding up the bills for the 6
Posted 16th Jul 2011 at 21:34
colgti6
Posted 16th Jul 2011 at 21:35
Rich E Forum Admin
No, not on the 306.
Posted 16th Jul 2011 at 21:54
colgti6
cheers rich ive just bought the car it needs the cambelt done and radiator and rear discs and pads so i gotta spend a bit off dow on it before i get to go out and play
Posted 16th Jul 2011 at 23:01
cdgray
Cheers for the replies everyone!
Managed to get back in with a combination of pressure on the piston while winding with the bleed nipple open, so panic over!
So new discs and pads all round and calipers painted silver all sorted. I did notice that my pads are wearing unevenly, both in terms of each set and on either side. Is this normal or a symptom of a problem with the system?
Posted 16th Jul 2011 at 23:18
gilesy
Take them apart again, and grease the sliders. You will probably find they are all gunked/fouled/rusted together
Edit: that means remove all the shite, scotchbright them down to shiny metal and then grease them up
Posted 16th Jul 2011 at 23:36
mechanical_repairs
Glad you managed to sort it in the end mate, I actually found a pair of calipers in the end too. Lol
Carl
Posted 17th Jul 2011 at 17:56
gtisid
mine wore unevenly when i put them back together wrong!!! if they are wrong the pads will get spat out eventually . turned out i put the little piece of metal that retains the clips in upside down
pugless
Phase 1 GTI 6 1996-1997
Subaru Impreza GB270 2007-2008
rare spiderman comics
same day international courier
Posted 17th Jul 2011 at 20:13
