displaying posts 1 to 2 of 2
Author Subject: coolant fan problem
dan86
hi all, wonder if anyone can help? My mate has got a 1.6 "v" plate 306 with aircon/twin fans like a "6". It seems to almost overheat and then the high speed fan cuts in at about 110 degrees to bring the temp back down.Its as if the low speed side of things isn't working, but if i pull the brown plug off, both fans start on slow speed and then go on to high speed after a couple of seconds. the air con has no gas so doesn't work.
Any ideas? Thanks in advance.
Posted 15th Jul 2011 at 00:36
djsy2004
i had the same problem and it was the temp sensor low speed kicks in about 97 and high speed 107
Posted 17th Jul 2011 at 01:00
