Author Subject: 280* cams
dav1
just quick question do you need to re-move oil spray bars for 280* cams there newman ph4's thanks
230bhp 205 gti6
Posted 12th Jul 2011 at 01:25
Rich E Forum Admin
It will depend on the peak lift not the duration, and bear in mind that you can space them out a little to get a little more room.
Posted 12th Jul 2011 at 01:32
devere
With my Kent PT84's i just crimped the spray bars a little bit over each lobe. Little but of a funny shape in places, but it still works as it should, and its held down fine with the cam covers.
Posted 12th Jul 2011 at 01:40
dav1
good idea how do you know if you dun it enough? dont suppose you got a pic? how can you space them out abit to if the cam cover holds them dwn? cheers
230bhp 205 gti6
Posted 12th Jul 2011 at 01:49
Take the rocker covers off anf turn it over by hand with a breaker bar on the crankshaft pulley nut, if it clears fine, if not remove the spray bars and try again.
Posted 12th Jul 2011 at 18:41
thelegendofando
I spoke to Dave at Newman cams and he says he's not heard of the PH4s hitting the spray bars, however the maximum lift would suggest that they do.
I can also assure you that you will need new valve springs to avoid them going coilbound.
I was going to get some PH4s, then I discussed it with Dave and he talked me into the PH2s instead.
205 GTi6 - work in progress
Posted 13th Jul 2011 at 04:19
dav1
springs are installed all ready catcam springs. so just the fitting an sorting spray bars I think.
230bhp 205 gti6
Posted 14th Jul 2011 at 01:50
dav1
Ditched the spray bars now. popped the rocker cover of and loads of oil from the splash so not an issue. engine in and running and it sounds angry LOL . getting mapped on Thursday ready for pugfest great.
230bhp 205 gti6
Posted 18th Jul 2011 at 01:54
thelegendofando
Surely you'll end up with oil starvation on the far end of your cams? However, saying that, I've heard Pug1off have removed a few and had no problems.
Posted 18th Jul 2011 at 02:45
thelegendofando
Btw, video of it ticking over? Big grin
Posted 18th Jul 2011 at 03:13
dav1
Got it mapped today at mikeanics in Congleton 219.7 bhp. good ehh.His rollers are very accurate to not like some ppls pub talk rollers. He's decided to keep it a day extra to make it bit more drivable. Not just like a rally car.pugfest here we cum.
230bhp 205 gti6
Posted 21st Jul 2011 at 00:33
rallyeash
whats the rest of the spec?
309 3dr K20 Type R
Posted 21st Jul 2011 at 00:39
dav1
87mm hi-comp pocketed pistons made for longmans by omega. (found this out the other day cus bought them 2nd hand),arp bolts, Newman ph4 cams, omex ecu, weber throttle bodies, 330cc injectors, rebuilt head(lapped valves,head skimmed etc.)
230bhp 205 gti6
Posted 21st Jul 2011 at 01:02
rallyeash
nice, yeah hp sounds about right Smile what are weber tb's like?
309 3dr K20 Type R
Posted 21st Jul 2011 at 01:07
dav1
some one told me there made by jenvy or same as but yeah there good an sound the tits. if I extended the trumpets would it have the same effect as the satchel bodies? going pug fest so would be interesting to have look at your car.
230bhp 205 gti6
Posted 21st Jul 2011 at 01:18
thelegendofando
Very impressive! I didn't know you were so close dav1, I'm only down the road to you and I'm building a very similar spec engine.
Does webber throttle bodies = carbs or you still running injection?
Did mikeanics map your omex? is that their prefered ecu?
Sorry for all the questions!
Posted 21st Jul 2011 at 01:31
dav1
yeah there injection. mikeanics mapped it an does prefer omex but he can do others still. were bouts are you?
230bhp 205 gti6
Posted 21st Jul 2011 at 01:49
thelegendofando
Ah ok, that makes my ecu choices easier.
I'm only in biddulph.
Posted 21st Jul 2011 at 01:50
dav1
did you buy my mates woosner pistons?
230bhp 205 gti6
Posted 21st Jul 2011 at 02:02
thelegendofando
Potentially, got them from near leek
Posted 21st Jul 2011 at 02:19
