Author Subject: 306 xsi overheating
djsy2004
hi im new 2 the forum just got a 306 2.0 16v xsi, bought it with blown head gasket cheap, ive done headgasket and had head skimmed and engine runs but getting hot quick the water system just wont bleed, the fans work and the heater matrix has been bypassed as it was leaking, the metal connection on the top raditor hose that connects to thermostat housing looks abit tatty do you think this could b sucking in air or should i look elsewere thanks wayne
Posted 12th Jul 2011 at 01:14
colgti6
take the thermostat out and put it in boiling water if it opens it works if not its f*cked, or u could try flushing the water system there could be a build up off lime scale. How much did u pay for ur headgasket all together ?
Adding up the bills for the 6
Posted 17th Jul 2011 at 03:39
djsy2004
its cost me about £150 at minute to fix done the work my self, thermostat working fine its new and i tested it before fitting
Posted 17th Jul 2011 at 12:07
aaron6
Put 2 of the wheels onto the curb to try and coax the air through. I had it in my birds Zx where the Bugger wouldn't bleed after doing a head rebuild. Got hacked off in the end and drilled a tiny hole in the thermostat. Been fine since and 3 years down the line still going strong. And col... Where ya from in maidstone? what car you got? Come to a meet fella. There's loads of us in the Kent mob and would be great to have another... Smile
Posted 17th Jul 2011 at 16:58
ling-ling
So what did you do to fix it?
Ling-ling is no pet! Ling-ling here to kill, and to give children seizures!
Who is Ling-ling?
PH1 "(now not Rusting) Blaze" GTI6
Posted 17th Jul 2011 at 22:55
