Lethal
| Author | Subject: 306 Rallye won't start |
rallyemagic
Newbie Location: Ballymena Registered: 03 Sep 2010 Posts: 1 Status: Offline |
My Rallye is turning over okay but not firing. I noticed that when I turn on the ignition the oil level/temperature indicator is flashing. I'm fairly certain that it normally stays on solid for about twenty seconds. Any ideas what this might be?________________________________________ Lethal |
ablister
Senior User Location: fife Registered: 30 Oct 2005 Posts: 522 Status: Offline |
check the fuses in the interior fuse box, you might find the 5 amp one for the immobiliser has blown________________________________________ 306 rallye, Richard Longman enginerc10gt |
gti6power
Junior User Location: Barnstaple Registered: 05 Mar 2011 Posts: 77 Status: Offline |
the reason it flashes is because the oil level is getting low, i get the same problem with my gti-6 |
Fuel pump priming? Check the fuses as mentioned.Crank sensor Immobiliser issue Relay behind the battery box is dead/full of water ECU has died (random though) ________________________________________ Nothing to see here |
swiftyboi006
Fuel cut off?________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
