Author Subject: Heavy steering?
judley
I've just acquired a 205 GTI-6 which seems heavy on the steering to what I'd expected. It's supposed to have a 2.2 rack but I think it's more like a 2.9. I've had the PAS checked to make sure it's working and it seems to be Huh?
The car does run quite a bit of camber on the fronts (2.75 degrees) so could this be making the steering feel heavy?
The reason I ask is that it will affect the LSD choice when I have it fitted shortly (assuming I can get hold of one). LOL
Cheers,
George
Posted 9th Jul 2011 at 22:00
Scrompy
Aka Quagmire83
Stop being gay, 205's aren't supposed to have power steering.
X-Box Live gamertag: Scrompy
PS3 tag: Scrompy
Posted 9th Jul 2011 at 22:21
judley
Well that's exactly what it feels like now mate! It's no bother really but it may make it a handful in tight turns with an LSD making it heavier........
Posted 9th Jul 2011 at 22:23
Scrompy
Aka Quagmire83
May sound like a silly question but have you checked the steering fluid level?
But also bear in mind that 205's, even with power steering are still on the heavy side. It's just there to help out in carparks.
PS3 tag: Scrompy
Posted 9th Jul 2011 at 22:44
judley
I haven't checked the fluid level mate but will do so, cheers.
Posted 9th Jul 2011 at 23:07
krisb
Check the pipes for kinks and bends too.
www.krisb.co.uk
Posted 10th Jul 2011 at 03:11
mattgti6phase2
As said check the fluid.
If it's desperately low top it up and then turn lock to lock a few times to rid of any air. SIMPLES Thumbs up
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 10th Jul 2011 at 05:17
miles
The most common problem is the UJ failing, This can be the outer or inner ones but the outer where it fit's onto the rack is normally the worst out of the 2.
Next is the Ram, Rack or pump
If the Fluids low you normally feel it getting jerky when turning as would a kinked pipe
The LSD will make no difference in steering weight
www.pugracing.com
Posted 10th Jul 2011 at 08:02
judley
Thanks guys, that's excellent information. I can also feel a light knock throught the steering at low speeds which may be another symptom of a worn UJ?
Will get it checked out tomorrow anyway Big grin
Posted 10th Jul 2011 at 11:51
scotzman
the light knock is probably a drop link
Posted 10th Jul 2011 at 12:51
judley
Just replaced the offside droplink last week and that helped mate but the noise is still there, albeit slightly better Whistle
Posted 10th Jul 2011 at 13:09
sickomotorsport
LOL
Posted 16th Jul 2011 at 00:47
judley
Well the steering UJ is to be replaced as there is wear in the joint. Power steering fluid was ok so I hope for some lighter steering next week when I get it fitted ;-)
Posted 16th Jul 2011 at 01:09
sickomotorsport
over inflate the tyres old used car salesman trick
Posted 16th Jul 2011 at 22:32
