Author Subject: low boost with decomp plate
kenny phase1
i have a phase 1 gti-6 that iam getting parts to low boost charge it. iam looking at getting the decomp plate from dp enginering. my aim is to get the car to around the 300bhp mark. i have rebuilt the bottom end with new piston and rods all standrd but brand new. I have also used ARP bolts and acl bearings. can anyone shed any light on the decomp plate as to if that would work? Thanks kenny
kenny
Posted 9th Jul 2011 at 16:36
if youre going low boost just leave it at the standard compression ratio, will be more drivable (low boost cars actually have more torque low down than high boost)
Posted 9th Jul 2011 at 17:04
kenny phase1
Really didnt know that.I just want a little more power as a friend of mine has a 306 rallye on throttle bodies high comp pistons etc.... running 238bhp and he keeps up with low boost not a problem...
kenny
Posted 9th Jul 2011 at 18:33
go high boost then....
low boost should be quicker if its running right unless your mate has a larger capacity engine with more torque...
Posted 9th Jul 2011 at 19:27
bobdylan_55
low boost are around 240bhp so id imagine if the other is running 238 it wont be far off.
Im running a decompression plate in mine and it seems ok so far. Im running 15psi at the moment, but ive had 21 through it and ran fine.
The advantage of a decomp plate is that if it ever does go, usually the plate is the first part to break, so instead of knackering the whole engine, you can just replace the plate. Try ferriday engineering, did mine for £160 posted with the non setting sealant that you have to use.
309 GTi6-T
Posted 9th Jul 2011 at 19:38
rich_w
A de-compression plate will work fine, and you should be able to run the 300 BHP you want reliably.
I wouldn't drop the compression too much though - I would go for aroun 9.5:1.
You will need a custom re-map rather than using our generic software, due to having a bespoke set-up too.
Cheers,
Smile
Contact Details:
07732 822546
Posted 10th Jul 2011 at 21:32
kenny phase1
is you 6 charged tho?
kenny
Posted 13th Jul 2011 at 01:48
kenny phase1
it has 86.5ml pistons newman ph4 cams solid lifters head work maniflow manifold and system 45 jenveys dta ecu.
kenny
Posted 13th Jul 2011 at 01:50
kenny phase1
No longer doing this due to a big change in work.
kenny
Posted 13th Jul 2011 at 17:56
