Author Subject: aeroquip hoses / braided fuel lines
springs
I'm looking at fitting the engine bay side of the car with Aeroquip hoses. I'm aware that i need AN 6 sized connectors. I'm going to get the weld on ones for the fuel rail but i'm wondering what ones i need to use on the other end of the fuel lines which go back to the plastic connectors by the brake servo.
Posted 9th Jul 2011 at 15:57
springs
anyone?
Posted 10th Jul 2011 at 20:07
The tank end unions are plastic push fits and unsuitable really for aeroquip style hose. unless you chop them otff the pipe and use jubilee clips to fit them to the new hose.
Posted 10th Jul 2011 at 20:18
edsonmassao
my mechanic made for me, my fuel hoses were always leaking after some months...
I will put only the links of the images because they are in great resolution, ok?
http://i51.tinypic.com/2s7b2o1.jpg
http://i53.tinypic.com/6919gw.jpg
http://i55.tinypic.com/nl61w0.jpg
Hmm, I donīt know how my mechanic put these fuel braided lines...
Posted 19th Jul 2011 at 23:33
rallyeash
use torques.co.uk for all your fuel fittings, much cheaper Thumbs up
309 3dr K20 Type R
Posted 20th Jul 2011 at 02:26
springs
i'm looking for more info on how it connects to the rest of the fuel lines etc..
Posted 27th Jul 2011 at 02:41
Torques do an An-6 to male push-on hose barb connector. As said check out their ebay shop Smile
Posted 29th Jul 2011 at 13:48
springs
you mean:
http://www.ebay.co.uk/itm/6-AN6-STRAIGHT-8mm-5-16-Barb-Hose-Fitting-/170658041438?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27bc030e5e#ht_638wt_905
Posted 30th Jul 2011 at 15:24
do these fit the pushfit connections for in tank pump and the fuel filter?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 30th Jul 2011 at 02:22
spiky
contact him first, mention my name and get discount too Big grin
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 30th Jul 2011 at 13:19
No, put the barb in the original hose as close to the tank as possible and use the original hose into the push fit on the tank. Or take the hose barb/AN 6 adaptor to a machinist and have him turn the adaptor down on a lathe to the same diameter as standard fuel hose and push that into the female connector. You may need to get a fairly large diameter barb (say 10mm?) to have enough material to machine off safely. Its not worth the effort really though, I'd just use 4 inches or so of the orginal plastic hose, then fit the adaptor and jubilee clip, then run braided hose the rest of the way.
Posted 30th Jul 2011 at 16:24
chris with a pug
I am running 2 8mm pipes from the pump with those push fit connectors in the end. Torques are spot on and he also has does the brake pipe connectors too, brought all my stuff from him so far and not had a problem and his customer service is spot on. If you email him and pay outside of ebay he does a good deal too.
Posted 31st Jul 2011 at 21:53
