Author Subject: Best way to remove an engine?
aphyx
Which is the easiest way to remove the engine?
Hoist it out from the top, or drop the engine out and lift the car over?
Many thanks
Onward to the Edge!
Posted 5th Jul 2011 at 22:56
mattym129
out the top.
mine has been in and out 3 or 4 times since i bought it, easiest way is to remove the front bumber along with slam panel - just 4 bolts and the headlights etc.
hope this helps
Posted 5th Jul 2011 at 22:59
pugjim
You have to lift it out at an angle with the gearbox end facing down a bit or it will catch on the inner wing.
Posted 5th Jul 2011 at 23:37
aphyx
Cheers guys
Will be attempting this shortly.
Onward to the Edge!
Posted 6th Jul 2011 at 02:01
fozzy_255
Easiest way i have done it was remove bumper slam pannel etc then cut the cross member out, no good if you plan on keeping the car though RazzP
As above thought out the top at an angle
Posted 6th Jul 2011 at 02:05
pugjim
Oh another thing to do is take of the breather hoses from the cam covers as the lifting hook will bend and kill them if you dont.
Posted 6th Jul 2011 at 03:02
