Author Subject: SRI engine codes
bainsey6403
Hi,
In the process of building a 16 valve turbo lump for the gti-6, i have the turbo ready and have fabricated the manifold already, but i would like to use the 406 SRI turbo block, now i read somewhere there are two types, one with dished pistons and one with flat top pistons, now i believe i need the one with flat top pistons but I'm not entirely sure. Can anyone point me in the right direction and give me the correct engine code so i source the correct engine! Any help would be greatly appreciated, Regards Dan.
Posted 5th Jul 2011 at 15:48
bobdylan_55
both were xu10j2te, however i believe the had different later part numbers
142bhp model was RGY
147bhp model was RGX
there is also xu10j4te which is the t16 and is cool
309 GTi6-T
Posted 5th Jul 2011 at 16:10
iirc the flat top were lower compression of the two, the crown sits lower down the bore, but it's not a significant difference.
Posted 5th Jul 2011 at 16:30
bainsey6403
Ideal, thanks for the info, so which of the 2 engine codes you have given should i be looking for?
Posted 5th Jul 2011 at 18:14
